Yeah i all ready sent them an email Kingy getting the Advan Neova AD08's for the R32 and i'm gonna get them New Hankook Ventus R-S3 285/35R18 for the R33 as they don't make the ad08's in a 35 profile in 285's, mackay roads are to shit house for 30 profiles. They give these new Hankook's a good wrap they are a 7.8 and the AD08's are 8.4 on tire rack so i'll give them ago, slightly cheaper aswell.
Hankooks
Advans
Yeah I borrowed a guard roller and did them myself, turned out pretty good I thought, didnt crack any paint... Not bad for a first try :) haha
They are 265/35 rears, factory arms etc. Just lowered a little bit, probably an inch maybe slightly more.
Still tossing up between rear camber arms or just camber correction bushes, will have to decide and take it in for a wheel alignment sometime soon
Think the camber at the front isnt to bad so not sure if ill bother adjusting front camber
Yeah adjustable arms are nice to have, but if yours is a everyday driver i would go with camber correction bushes because aftermarket arm have pillow ball ends (rose joints) and depending on what brand u buy they tend to flog out a fair bit especially mackay roads. I nearly have the full ikeya formula catalogue on my gtr, they are awesome bits a gear but cost you a arm and a leg...if only i had a spare 2k for front and rear lower adjustable roll centre kits...you wanna sponser me kingy lol
I got a full time job sponsering my own :nyaanyaa: lol...
You would not believe what i got quoted for a light globe at autobarn yesterday... $345 and have to order it in gotta be kidding me...
Is there anywhere in town that sell HID globes off the shelf??
Yeah i done the rounds today only place i could find that stock HID were ashdowns in paget but they didn't have the right one. and were 180 per globe lol
Got a pair off ebay for 110 from melbourne. Hope its the right one so many to pick from.
So I had to roll the front guards on my car today, thought they werent an issue but chewed a bit of tyre turning into a driveway the other night lol so decided to fix it today.
Hopefully all good, didnt do much damage just put a very small dint where one of the screws from the drivers side inner guard hit the other part of the guard but oh well. Not a bad job and it was free
Bored, Thought I'd put photos of my first car up seen as I got a bit nostalgic posting a photo of the engine bay in Bens build thread haha
And what it decided to do on my 18th birthday:
Aftermarket lifters are a no-go in RB30E's
Edited by 89CAL
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
