Don't know if any of you lads are interested but we are getting team shirts made up for our R32 GTR Drag Car, Prices will very depending on how many we order but they will be approx $40. Just PM if you do want one and the size you would like.
Cheers Benny
Will look something like that:
Is anyone interested in my HKS GT2835KAI turbo?
Will probably look at selling it soon and just wanted to see if anyone local wants it
I made 255rwkw with it @ 18psi
just EOI at the moment. Probably just the turbo itself as well as the oil lines
Could be interested bro
yeah i might be interested too callan ;)
0448 233 105
He's from Mackay.. Knows this shit backwards. He's a guy like you and me, and the rest of the crowd.
Very good with suspension too due to the whole drifting scene.
Thanks again Jono i gave him a call, he's going to check it out on Friday for me
damn ben you guys don't stuff around. it'll look good once ya get it pieced together.
cal- go the 3076r, it will change your life :P
nic- just finish the sil80, if ya go a 3076 on the 34 don't go the 6 bolt housing, it'll make decent midrange power but for what a dump pipe costs go the .82iw
I'm pretty set on going Hypergear right now. After the cost and annoyance this HKS turbo has caused my I'm reluctant to go for another one (pretty sure Ben was talking about his HKS turbo he is selling)
anyway, the main benefit of the Hypergear turbo is that I can just change my mind whenever if I want to go ext gate or even if I want to get updated parts/housings/wheels.
It's just a bit of 'playing it safe' I guess you could say on my behalf, Stao is local and easy to contact/deal with.
Having said that, its not like they are comprimising to provide any of this, I've seen plenty of good results
Cal, the hypergear won't do much better than the 2835. There is also nothing wrong with the GT3037 HKS. They have a better rear housing and IW than the garret version. They also make more power because they have a larger 76mm compressor.
The turbo I'm going for will be 300rwkw @ 20psi on pump fuel, full boost 3700ish rpm (getting 6boost manifold)
The HKS 2835KAI is only making 255rwkw @ 18psi with full boost around 3400rpm
I've spoken to others and this is all they are making
The Pro S that I originally wanted, sure. Would be more then happy with it
But the KAI has proven to be nothing compared to the Pro S.
There must be something up.
I made 300rwkw with a garrett GT3076 and 0.63 rear housing at 18psi - 20psi. Full boost in third at 3200rpm. That was with the little IW too. You can get a custom garrett IW that is bigger and handles high boost better.
The 0.82 rear housing shits 300rwkw in at 18psi. About 500rpm lagier though.
Its a direct replacement to your current turbo too. Well almost, I think the HKS rear dump pattern is a little different but that is easily fixed.
And why are you wasting money on a 6 boost manifold? All of my results were with a standard manifold. If you want to make the standard flow better (more like a HKS cast one) then hit it with a die grinder and clear out all of the lumps. I did that with the standard manifold I used for my RB25\30 build, and bam, 320rwkw with 20psi from the same Garrett GT3076, 0.82 rear housing, IW. Had Tomei 256\256 poncams though. Full boost in 3rd at 3000rpm, and 820nm of torque at 3000rpm.
Its a weapon. Still going good too.
My advice?
Get a GT3076 or GT3037, 0.82 rear housing.
Port your standard manifold, and get it faced
Port match your Rear housing entrance to your exhaust manifold output
Get some Poncams, 256/256 or 262. Anything bigger is a waste for the RPM range you are using.
Get someone to look at your tune
    • What's on the front of their building?
    • Jax Tyres Smithfeild Ive gone there a few time, well for tyres. on my 3rd visit I spoke to the dude and told how i just got slugged for rotors, brakes ect. His reply was golden; have you read whats on the front of the building. Never forgot it.       before picture, good friend got all these goodies installed.  Well time to study, servicing, maintenance all before this weekend driving lesson.
    • Hello, first of, I’ve looked at many threads on this code but none have helped me, if you know one that will help me feel free to post a link.   Now to my problem. Recently I was driving and noticed the check engine light came on. I went home and did the test to see what code it gave. I got the 21 code but everything seems fine with the car, no misfire, idle is good, acceleration is the same as when I bought it. I mean no signs of obvious failure. If no misfire is happening I can rule out the coil packs right? Which is about 98% of posts saying it is. If anyone has had this happen and found the issues let me know please. No other lights are on.   The car WAS due for an oil change. I since then changed it so idk if that triggers code 21. Either way it hasn’t turned off.
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
