So who actually has a car that runs at the moment?
Think its about time we had a cruise or something. But all depends on who has a car to drive
Nah got no cars except the R32 which does not go cruising.
Yeah its not exactaly a stealth cruiser :P
Was just thinking you still have the NUR33 plates...... What are they going on next? Or are they just wall posters now?
Edited by 89CAL
NUR33 Plates are going on the Drift Car ;)
Got some new goodies for it this week will be putting the engine back together over the next couple of days. Just gotta order the new intake and exhaust manifolds.
All this talk about cars annoys me.. I want to buy another but I don't know what to buy.
Any suggestions?
Buy anything lol, GTR's are good but they come with a very expensive Tax epically R34's just ask Kingy, High Quality aftermarket parts are super expensive (Been there done that) and if not done right has great potential to bite you in the arse hard like any RB engine would. My choice of car at the moment would be Evo IX hands down. Cheap to purchase, cheap to buy parts for and handle anything you can throw at it.
My missus has given me the green light for my next project car 67 - 69 Chevy Camaro Coupe with LS9 conversion Old school car with New School running gear with a JDM style to it, will be a few years before that happens lol. Starting to research how that's gonna go i want a nice weekend cruiser with infinite Nm of torque :woot: .
I got one in Victoria street a few years ago. Never got around to paying it and never heard anything about it again. Maybe just lucky
definitely lucky! it says on the ticket that if its not paid the balance will increase. i have til 11th next month so whatever ill just pay it. still annoying as f**k though
I'm up for a drive for sure, can bring a few more guys with Skylines too.
Buy a V35 Jono :) Leon's missus has just got a white one
Havent seen it in the flesh but it looks pretty damn nice from the photo I've seen
Just copped a f*cking $80 parking fine while i was getting a haircut in victoria street. How can they issue fines when there's only 10 parking spots in the whole street, shits f*cked.
Yeah I got one for parking in the middle of the street outside Hogs Breath once when I was away for about 5 mins getting sushi. It is a loading zone, but they hardly ever patrol that area I think. Just unlucky really
On another note. I emailed Titan motorsport about an ATI balancer for an RB25 and they said there is no such thing and werent interested at all in helping
Emailed another American performance parts shop and they are going to contact ATI or get a custom one made.... lol no idea how expensive that is or if its just like one of the others I've seen which is just a mix of a few different ATI balancers
They won't make one for a RB25 you will need to get one for a RB26
Got a Little Bit done today not a great deal but, picked up some more bits today like a Full Z32 Gearbox Conversion Kit all Machined up ready to bolt up and also got a ATS Triple Plate Clutch for good measure to handle plenty of abuse :rolleyes:.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
