Cheap shit cheese cutters they use, then they say i can spin the wheels in 4th sounding all cool and shit, then i say how wide are they? Reply: 235's What brand of tyre? Reply: Nankang. My ride on mower could spin them in 4th you f**kwit go buy some decent shit ffs!!!!! :domokun: f**king Falcodore drivers are retarded.
LOL so good. I can't stand them!
As immature and lame it is. I Like beating some young P-Platers in there brand new SV6's that think there car is the fastest thing out there. Still have a video somewhere of me racing one, where I completely stuffed the start and he got a bit of a lead, then I flew past him half track
One day I'll grow up lol
Also suprised myself by beating a couple of XR6 Turbos with a few mods.
But looking forward to having 300+rwkw and giving it a crack :)
Edited by 89CAL
Speaking of racing.. i was just coming home (slade point) and i had a black SS ute (2008+) come up beside me and accelerate then slow down egging me to race him.. the f**k is he thinking with a V8 trying to race me in my NA on my p's.. he had some chick in the front seat probably trying to impress her. I just stayed at 80 being the law abiding citizen that i am.. and the fact that the cops were just behind us at the forgan bridge, then he gunned it up the road after trying for a couple of minutes. Sure if it was a normal commodore i might have raced him, but what's the point with a NEW V8...
Edited by Seano350GT
Also getting really tired with Palmyra drags, every time i go it's just commodore's and xr6's. No variety at all unless it's a 1000hp machine that you stand absolutely no chance against obviously..
As long as we go to Palmyra with the R32 they don't stand a chance we run constant times 9's now, GTR's will dominate Mackay when we represent I'm nearly tempted to buy another GTR just to prove my point but my 180SX will dust halve these falcodore driver"s, I don't build slow shit.... 11sec drift car will do me just fine :yucky: + my/Richo's 2JZ Supra project will keep them on there toes hahaha...... f**k'em
That's right haha, 11 sec drift car would be mental!
I got bored, some old photos:
Proof You've gotta start somewhere:
So anyway......
I need a set of lifters for a 25 (Hyd)
Can only find new ones from the states (There for 300ZX but same part number)
Anyone ever had to source lifters? Or does anyone have a set (used or new :) )
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
