Powertune sent me a 38 instead of a 44 that I asked for.
The 6boost manifold is for a 44. So i just gotta make an adaptor peice so it can all fit together.
Don't do it. Get the 38 swapped for a 44. You will regret using the 38
ummm also i pretty sure the 38 use the 44 foot.... they just have an insert to make it 38. might wanna check that. the out is 38 but im sure the in is 44 with an insert to make it 38 ;)
I think you are referring to the valve seat. Both have it I think
I got in contact with them today. looks like Im exchanging it for the 44. Thanks for your help, Dan.
Cool mate no worries. I'm not saying you WILL have problems but the chances are fairly high from what we see. Bigger gate is always better and if they are just going to swap it out, it's going to make things a lot easier, not only for boost control but also for fitment by the sounds of it
Just being a dick............
sort of would love to throw some Tial rear housings on the -10's and convert to external gate..... mainly for the whoosh / screamer noises. but eh, that's a lot of effort required.
There are no bad ideas, only bad execution
As far as i know to go the tial housings (no internal wg) id need to get vband dumps made and then work out how i was to plumb the gate/gates onto it all. Custom manis / gates on rear housings
Too much money to really convert imo. Easier to go highmount 30's or just a 51R / 4202 with split pulse!
But i do agree!
Edited by Force Fed
Ben Earl if you still lurk here- Stance Nation fb page just uploaded the sweetest pic of your 32 and Jordans R33 and another guys R34 can't remember his name. Has thousands of likes and tonnes of comments. Must be good to be recognised across the globe man!
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
