Dan,
thanks for your reply about the CAS... That helps answer the question big time!
Also, I have just loaded up the haltech software on my work pc, coil dwell time can be set between 0.2ms right up to 20ms.
This is 'tested' on Version 1.11.1 of ECU Manager.
I know they are constantly adding new things to the software + ecu's with each update.... so it may have not always been in there.
Standard dwell on left, max on right for illustration purposes.
Using a R32 / R33 Platinum Pro base map to work off
Yeah you can set dwell time but can only choose one figure for the entire rev range.
In something like a Wolf V550 you can set coil charge time over RPM and also over battery voltage. It has a full tuning table for both at 125RPM intervals
Quick voltage vs rpm for ign. dwell.
Obviously not as detailed down to every ~125rpm or there abouts as some ecu's can do but it's still able to do same basis.
I should probably have gone a bit further than using single axis of RPM and moved into the full map to cover more values.
edit - stupid me not attaching. fixed.
Edited by Force Fed
As per text mate. Am happy to see if i can find anything else that may have been added since yourself / Sean had a look. :)
At least they are bringing out new "features" on same hardware!
You got a promotion, Nick? From auto-sparky to car assembly? Haha.
At least you've got a project to work on.
im auto lek/mechanic now man... once i finish this car and finish building these new ones ill be into the workshop full time. instead of goin from 1 side to the other
Everyone should stop talking about finishing their cars off and actually do it :)
I want to do some more photo's
Took the fitting out of the filter/cooler housing on my block today, going to go chasing a replacement male to male fitting for it on monday for my oil cooler. Was going to relocate the filter but have decided I don't really need to and dont really have the room
Am thinking about doing a catch can setup but. just deciding on how to do it
umm autobarn actually sell some decent quality parts... and the price isnt even that bad (depending on what u buy)
doesnt matter what shop it is. its not nice seeing it go up in flames. specially when 4 little cun7s lit it up
Yeah jokes aside its not real cool at all, the fact that it was young girls setting fire to a toy shop a few weeks from christmas makes it pretty horrible
When I was 12 I never would have dreamt of doing that, Parenting these days has taken a slide for the worst
