Dan,
thanks for your reply about the CAS... That helps answer the question big time!
Also, I have just loaded up the haltech software on my work pc, coil dwell time can be set between 0.2ms right up to 20ms.
This is 'tested' on Version 1.11.1 of ECU Manager.
I know they are constantly adding new things to the software + ecu's with each update.... so it may have not always been in there.
Standard dwell on left, max on right for illustration purposes.
Using a R32 / R33 Platinum Pro base map to work off
Yeah you can set dwell time but can only choose one figure for the entire rev range.
In something like a Wolf V550 you can set coil charge time over RPM and also over battery voltage. It has a full tuning table for both at 125RPM intervals
Quick voltage vs rpm for ign. dwell.
Obviously not as detailed down to every ~125rpm or there abouts as some ecu's can do but it's still able to do same basis.
I should probably have gone a bit further than using single axis of RPM and moved into the full map to cover more values.
edit - stupid me not attaching. fixed.
Edited by Force Fed
As per text mate. Am happy to see if i can find anything else that may have been added since yourself / Sean had a look. :)
At least they are bringing out new "features" on same hardware!
You got a promotion, Nick? From auto-sparky to car assembly? Haha.
At least you've got a project to work on.
im auto lek/mechanic now man... once i finish this car and finish building these new ones ill be into the workshop full time. instead of goin from 1 side to the other
Everyone should stop talking about finishing their cars off and actually do it :)
I want to do some more photo's
Took the fitting out of the filter/cooler housing on my block today, going to go chasing a replacement male to male fitting for it on monday for my oil cooler. Was going to relocate the filter but have decided I don't really need to and dont really have the room
Am thinking about doing a catch can setup but. just deciding on how to do it
umm autobarn actually sell some decent quality parts... and the price isnt even that bad (depending on what u buy)
doesnt matter what shop it is. its not nice seeing it go up in flames. specially when 4 little cun7s lit it up
Yeah jokes aside its not real cool at all, the fact that it was young girls setting fire to a toy shop a few weeks from christmas makes it pretty horrible
When I was 12 I never would have dreamt of doing that, Parenting these days has taken a slide for the worst
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
