Crank should be getting balanced over the next few days. So I can finally start putting shit together :)
Got over the idea of cc-ing it. The shape of the piston domes and how it all sits just makes it more trouble then its worth. I already know its going to be between 8.5 - 9:1 so that's all good.
Get it all together and work out what colours I'm gonna paint everything. Sick of looking at the block how it is at the moment. Will look much nicer with some paint on it :)
Haha i have a couple of flat brim hats in the cardboard, the car will be dual purpose Rob just a matter of swapping tires and geometry, just wanna build something crazy and over the top, all my ideas i've wanted to do over the years put into one car.
Big f**k off GT Wing check! Low as f**k check! Massive deep dish wheels check! Sidepipe Titanium Exhaust check! V-mount intercooler/radiator check! Fully stripped out no dash and one seat check! Front splitter and Canards that would decapitate someone Fark yeah check!
Drive it like i stole it and hang the hell on, if it doesn't scare the shit out of me every time i drive it, white knuckling the bastard the whole lap and my arsehole chewing on that Bride seat then i'm afraid i have failed this project lol.
Haha that's brilliant, if you had a passenger seat i would of said you should get one of those dash stickers that say "SHUT THE f**k UP I GOT THIS!"
WTF are they doing with your engine Rob hand build they parts with a hacksaw and file, ring them slack kents up and put some fire under there arse, have you already payed them in full yet?
Haha yeah if freaking love that sticker should put one on the R32 lol
f**k that man you have paid in full it should be ready, i would have paid half now and half when i get it, that's ridiculous man who is doing the build. Does not take that long to build an engine, our Drag engine didn't even take that long, and it has custom built internals and we never paid the full bill until we went down and picked it up.
I don't mind to be honest... I know where it is and shit. JHH Racing is doing it. I trust him and he knows what he is doing. It is because of communication issues that its taking so long.
Shoulda done a JSA before I sent it down and made sure POS.comm was a control...
I hardly think anyone can call Will from JHH Perf. Engineering 'slack'.... Especially not when he builds most SEQ workshop motors, including Godzilla's..... One of the very few he doesnt is Elite's!
He currently has 8-10 motors sitting there..... I sort of doubt Rob's or mine are on the 'ultra urgent' list.....
Edited by Force Fed
What i'm getting at is if you generally have already paid something in full you shouldn't have to wait a lifetime to get it. E.g when you order a custom set of rims from Rays that take 3-4 months to be made you usually pay halve up front and the other halve when its ready to be shipped etc.
I know where you are coming from, Ben, but I also understand Will's side too. Total sercurity into the work
nothing worse than ordering $$$$$$ parts and the the guy disappears, only paying enough to cover half.
The only reason I was getting the shits is because I didn't know what the go was with it. Now I do, I have restored faith.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
