Anyone had any experience with Power Enterprise Injectors? They look like they might be good and come in 850cc side feed so might end up getting some unless someone can talk me out of it
Yeah i had them before in my R33 GTR i had 1000cc they seemed to go alright.
Jono i'm pretty sure there's still one there you can drive, the waiting list is supposedly 6 months as of now but i would go in and ask for either Vas (Indian) or Ben. Both really good guys to deal with and know their stuff.
My cousin doesn't get his til Feb 2013 he ordered it in Aug 2012. f**k waiting that long lol
Yeah i agree the boxer engine is a huge disappointment i wouldn't buy one until the price drops so i could do a engine conversion. I bet in a few years time ebay will be full of 2nd hand boxer engines for peanut prices lol.
Anyone know anyone who wants some of this stuff.
For Sale:
SR20 Forged Bottom end Package Used but in very good condition.
- Eagle Forge I-Beam Rods with ARP Bolts
- Venolia Forged Alloy Pistons measure 86.5mm
- Stock SR20 Crank has ACL Bearings but should be Replaced when rebuilding engine.
Take the lot for $700 ono
going stroker ben??
thats cheap, i'll let a mate know about them
cal- have you looked at using a rb26 fuel rail and then get a set of id's? the rail bolts straight to a greddy plenum and you keep the std reg.
going stroker ben??
Seems more hassel then its worth to go top feed at the moment. I think I'll paint up the stock 25 rail and just go some side feeds
did some playing around with my good head and the timing belt etc today, looking pretty good :)
Why so cheap
And why selling?
If you have been on ebay lately SR20 parts are cheap as f**k, Charging anymore is just ripping people off unless they are dumb dream boats and didn't bother to research. I have made and executive call to do myself a favour and go with Darton sleeves with 90mm pistons and a BC 91mm stroker crank kit giving me a total of 2.3L capacity. Combined with a Brand New P12 SR20VET head will get me the 700HP I would like to achieve. Turbo choice is unclear at the moment and since i sold my S13 head today its time to start investing in new engine components.
Yeah i am gonna tackle most of this engine build myself aswell i told my old boy today, its time to start assembling our own gear, sick of paying people a f**k load of money. If it blows up we will learn pretty quick not what to do and learn from it. See how it goes.
The only reason I'm doing this engine is because I wanted to build an engine. Expensive hobby that one. Next time I'll get an old engine from the wreckers and pull it apart and put it together, sounds alot cheaper :)
Looks like the ext wastegate setup is going to work with the smaller gate to. And everything spins nicely :)
If I get keen tomorrow I'll be putting the pistons in (Yes that photo is bare block basically) and doing the same sort of thing as I did today to make sure no pistons are slapping the valves as that would make me sad
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
