Thanks Sean, I will make another call. That dude must not have been too interested in selling me a car..
Jono,
Either call Ben or Vas, i had Ben over at my yard yesterday i told him i had a mate keen on an 86 he said there's one here to test drive but the wait is currently 3 months for the base model and 2 years for the GT-S or whatever the one is with the bodykit and spoiler.
Ben - 0400 422 628
Vasili - 0400 251 725
They will both help you out man.
Thanks mate, as soon as I get a chance I will organise something with one of these guys.
About oils earlier too, A mate sent me an interesting test of all oils. Seems Royal Purple and Penrite seem to be the best in these particular tests.
http://www.users.on.net/~pacey/sau/Oil%20Tests.pdf
Anyone know anyone who wants some of this stuff.
For Sale:
SR20 Forged Bottom end Package Used but in very good condition.
- Eagle Forge I-Beam Rods with ARP Bolts
- Venolia Forged Alloy Pistons measure 86.5mm
- Stock SR20 Crank has ACL Bearings but should be Replaced when rebuilding engine.
Take the lot for $700 ono
BENNY BOY THESE ARE H BEAM RODS MATE :domokun:
I think once i'm finally off these P plates i'll look for a tidy S15. Seems to be a shit load of SR20 bits and peices reasonably accessible and cheap rather than turning the V35 FI or throwing a Vortech on it.
thats why u mod cars lol... to be different. in saying that if u dont wanna spend BULK cash then yes lightly mod an S15, theres parts everywhere for them
Yeah there isn't many V35's in Aus that are Turbo'd or Supercharged so it would be interesting, but the only real downfall with my car is that there isn't a lot of people in the country that know a great deal about them and parts almost always have to be sourced from Japan/USA.
I still have 12 months.. so i got plenty of time to decide!
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
