Thanks Sean, I will make another call. That dude must not have been too interested in selling me a car..
Jono,
Either call Ben or Vas, i had Ben over at my yard yesterday i told him i had a mate keen on an 86 he said there's one here to test drive but the wait is currently 3 months for the base model and 2 years for the GT-S or whatever the one is with the bodykit and spoiler.
Ben - 0400 422 628
Vasili - 0400 251 725
They will both help you out man.
Thanks mate, as soon as I get a chance I will organise something with one of these guys.
About oils earlier too, A mate sent me an interesting test of all oils. Seems Royal Purple and Penrite seem to be the best in these particular tests.
http://www.users.on.net/~pacey/sau/Oil%20Tests.pdf
Anyone know anyone who wants some of this stuff.
For Sale:
SR20 Forged Bottom end Package Used but in very good condition.
- Eagle Forge I-Beam Rods with ARP Bolts
- Venolia Forged Alloy Pistons measure 86.5mm
- Stock SR20 Crank has ACL Bearings but should be Replaced when rebuilding engine.
Take the lot for $700 ono
BENNY BOY THESE ARE H BEAM RODS MATE :domokun:
I think once i'm finally off these P plates i'll look for a tidy S15. Seems to be a shit load of SR20 bits and peices reasonably accessible and cheap rather than turning the V35 FI or throwing a Vortech on it.
thats why u mod cars lol... to be different. in saying that if u dont wanna spend BULK cash then yes lightly mod an S15, theres parts everywhere for them
Yeah there isn't many V35's in Aus that are Turbo'd or Supercharged so it would be interesting, but the only real downfall with my car is that there isn't a lot of people in the country that know a great deal about them and parts almost always have to be sourced from Japan/USA.
I still have 12 months.. so i got plenty of time to decide!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
