Got home to find these on the kitchen table :) They are monsters, bigger than my 6pot AP's on 370mm Rotors. The brembo's are only 4 Pot for 330mm Rotors. Must say these Nascar brakes are gonna suit the 180SX perfectly. They just fit behind my Work S1R's which Is a bonus.
Mackay people! Know that it's a bit of a drive but the dinner and chats are back!
Continuing on from last years very popular dinner and chats, thought that we could kick off this year with dinner and a movie.
Considering that South Bank is cheap on cinema tickets and because they have decent food thought that that would be a good place to go.
Who: People who are interested in Skylines and cars as well as their significant others.
What: Catch Up for dinner and a movie.
Where: Grilled and then South Bank Cineplex
When: Dinner at 7 and then movie around 9:30pm, Friday 11 January, 2013
Why: Because its the first week back at work for a lot of people and we all could do with a break. It's also been a while since we've caught up, so why not!
How: Well, you drive to the car park and park your car, then walk to the restaurant. . alternatively, I'll be heading there straight after work so if anyone wants to catch up prior, we could always do that.
The movie that were planning on seeing is Hitchcock. They haven't released times as yet but they said that there should be a session around 9ish.
So, who's in?
So, who's in?
$400 fuel bill, but the movie tickets are cheap :P
I want to take my car to Brisbane one of these days, but will probably do it when there is a proper event on (And not sure when I will get the energy to drive it up there) Track day at Willobank etc would be the go. Maybe there will be a few others from here keen as well, if they ever have cars again......
Appreciate the invite though, shame we are so far away up here in our dark corner of the world :P
There are discussions about a few of us coming up your way. Pm some events that you guys would be interested in coming down for and well see what we can organise.
Also, if its a $400 fuel then you'd want to save as much on the movie ticket as possible right?
Rough estimate on fuel, and yes movie savings would help :)
Events here....... drags, drives or drifts is about the extent of what can be done here
Let me finish my car first and then I'll drive down with you, Callan...
I'm letting you finish it....... are you letting yourself finish it but? :P
I've found some motivation today and put my pistons and rods together, just hanging out for a second person to put the c-clips in. Damn they are little bitches to get in
Why Build an engine when you can take photos of the parts instead :)
IMG_3863 by 89CAL, on Flickr
Tried to get some photos of the colour I'm putting on the cam covers, its a bit hard but you get the idea:
Might get keen tomorrow and clean the block and get it ready for pistons and painting.
Yeah drags and the ocassional drift in proserpine is about all you can do in this town.
I'd be up for the drive, won't be for at least 6 months though as i've got time off in March and will be flying down.
Fark that i wouldn't rack up 2000km's to going to a meet, stone chips, tire wear, fuel, will be nearly due for service and spark plugs by the time you get home, trying not to get a speeding ticket. Lucky i don't own my GTR anymore i would be broke lol.
Car on the back of a trailer?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
