Hey Sean
Check this out would be a awesome investment:
http://www.skylinesa...22#entry6710922
I was just looking at that thread lol, i am a sucker for dish so i'm not a fan of these.
However, these are my next set of wheels for sure but probably in a 19''
Work Varianza T1S, they are discontinued but there's still a vendor in the states that's got a good supply of them so hopefully when i'm ready for my next set i can get my hands on these.
Edited by Seano350GT
Just get a set like my Work S1R's
JDM Concept have these 20" VS XX
WAS $3880, NOW $3180 PICK UP IN SYDNEY, DELIVERY IS EXTRA [save $700]
[F] 5-114.3 20X9.5 +6 A-disk [90mm dish]
[R] 5-114.3 20X10.5 +O O-disk [122mm dish]
COLOUR: [bKB] Black Burning
Z33 above is using the exact spec
i've never understood what the difference is between a disk and o disk, what is it?
yeah Tony loads of dish, they are meant to clear my brembo's too lol.
Ben i can't see those wheels on my work computer but i'll google them
Googled them, they look sweet i'd definitely want them in a step lip and in 19''. They are similar to miesters and even te37's
So Apparently the ARP bolts at their slightly higher then OEM torque specs caused the girdle to distort slightly and this is why the crank was locking up. didnt appear as a problem at standard torque but did at ARP torque settings.
So hopefully all good now
Today I managed to get the oil pump fitted up, sat the timing gear and plates in, knocked all the welsch plugs in, fitted the knock sensors and fittings to the block, (all will probably have to come back out but saves losing them in the mess i have) and dummy fitted the sump. Still trying to find an alternative to plumbing the rear head drain into the intake side of the sump. It's so busy on that side with the starter motor, alot of the wiring and water plumbing as well as the underside of the manifold. But its the best place to plumb it because of the way the sump baffle slopes. Guess it will have to wait till the engine is more together to see where it will fit
Yeah the turbo drain is an option. But the new turbo doesnt really have any oil restriction as compared to the HKS item I have. so will have alot more oil flowing through it. But realistically there wont be that much oil combined from the head drain and the turbo drain to prevent the turbo drain from doing its job.
think that might be the best option at the moment anyway, May just go with this. Yes I realise the head drain thing is either a good thing or completely useless depending on who you talk to. But as far as I can see, if your accelerating, your pushing oil to the back, so it cant hurt to have a drain there. My logic might not be right, but I feel it necessarty
It's not useless cal, just doesn't drain much.
It's useful because if you can equalise the pressure between the head and the sump, the oil will drain better.
For example, if the pressure in the sump is greater than the head, oil isn't going to want to head that way easily.
and pretty sure just cos theres no restricter in ur turbo feed its still like 1/4 or smaller then the size of ur drain, so i would think the drain will be big enuff for the turbo n head aswell..... does that make sense ?? ive had a few beers :cheers:
Edited by dysonest
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
