power cruise in September sounds good.. Hopefully my car won't be too far off maybe take it down to Bris in May for a tune, see how we go.. Need to pay the mechanic a few more beers haha.. ;)
Millions of dollars is more preferable :woot:
  • Like 1
I'm sure most of you have driven paradise st of late.... Wht a joke the upgraded road there is already started to fall apart ...... All the wet couldn't be doing it good but surely it has to have something to do with the quality of work carried out as well ?? Then what would I know I'm a boilermaker by trade lol
Mackay Regional Council have a tendency to do roadwork's in the wet season... dumb f**ks instead on hooking in on the winter months and getting it done properly. They need to asphalt everything once instead on shitty bitumen repairs 10 times over.
yeah they love doing half-arsed roadworks then scratch their head when the wet season comes wondering why the road doesn't hold together for longer than a week without giant crater-like potholes appearing.. always happened in Mackay lol. Amazing how different the roads are in Townsville compared to here..
Yeah cheers mate ..... Went and got a wheel balance done haha what a drama that turned out to be as it had a lock nut on each rim which I couldn't find the key nut for so me assuming that any wheel and tyre joint would have a grip socket to remove them went down to only find out they didn't and were not willing to remove them with a ordinary socket which I have done tons of time .... So back home I go and 10 minutes later the lock nuts are off haha should have done it myself first time around ! Anyways turns out each wheel was out between 10 - 30 grams lol feels heaps better now !
kool kool. well ill send ya a msg when im heading home and ill chuck em in the back of the ute and head round. ill bring rotors and rear calipers if you want. front sitting on there so they dont leak out.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
