Yeah tomoro night. Ill head back down when i put new comp in and tune new turbo. Speaking of which did u still have the data logger for the d jetro , and the intake that had those fittings in ben. Make it a swap not a drill out and tap
Ah I go to work tomorrow night but I will be attending Slamfest next weekend at Palmyra.
The GTR will not be attending. The engine has currently been removed, the clutch was absolutely rooted, has been sent to NPC for rebuild and slight modification. Engine got all packaged up today and overnight freighted to Godzilla Motorsport for a B'day rebuild / freshen up. The block is getting grout filled solid so will be stronger, block is also getting O'ring treatment, head getting super-tech valvetrain for higher RPM, new Maran 5000cc fuel injectors for the Methanol Fuel, plus other this maybe. All in name of more power and torque will be up around 1400HP :woot: that should increase our top end MPH and get the low 8's.
Yeah I got all the datalogger gear hear Jordan just got to come get it, as for drilling out No.3 &4 intake runners for the map sensor fittings, I got another idea for that, save you pulling the whole plenum off. I will do it how Kingy's old D Jetro setup was and use the 2 points at either end of the air equaliser rail. It worked fine on his car.I'll try catch up with you next week and show you.
I know lol. Depending on what he wants to get out of it, FC-Pro graphs and records data alot better then FC edit will. But FC edit might be all he needs. Offer is there Jordan if you want to do some data logging
I have no clue lol. I just need it for grant so he can tune it once its in. And it will be going to vipec or something in the future just want to get rid of afms. When are u home ben. Im heading out of town tomoro for a week or so. So if next werkend ur free ill come round. And will let u know cal cheers for that.
Ahh ok
Yeah I perfer FC-Edit for tuning. FC-Pro is just great for logging if you have a problem. You can record a run and then play it back and view around 12 parameters at the same time on playback. its a good program
ah righto, to easy cal, ill let grant know and see which one he would want. matt came round and i seen what you was talking bout ben. easy as. just a splice into the boost lines, just need a few t pieces from somewhere and should have it sorted within the month.
Just in case anyone is interested. I have some AH Astra headlights I want to get rid of. Trying to sell them for $20 on facebook but free to anyone on here who wnats them. Bit of a long shot anyway. The lenses are just a bit yellowed, other then that no real issues
Let me know
For those who missed it on Facebook, going to do a little plug for Craved Coatings here. Did a fantastic job of my cam covers, very happy with the colour and finish on them. They look great in real life
Photos:
1048514_10151487800167793_2038528849_o_z
1063742_10151487802862793_1199754537_o_z
They're pretty average quality photos as they are only off my phone but you get the idea :)
Got a better set of injectors sitting in the shed if anyone is planning on running over 500hp on E85. I got 6x 2000cc ID injectors have proven to make over 1000HP old drag car injector, or maybe I keep them for my next project.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
