about 4 months ago i decided to sell my 200rwkw r32 gts-t for something a little different.
decided to import an aristo cos they are very cool and very unique.
got the car last tuesday and it got registered this morning.
pics here
http://members.optusnet.com.au/linxus40/aristo/
warning: they are not 56k friendly.
after a few days of driving it all i can say is that it truly kicks ass, if your in the se suburbs of Melbourne you might see me cruising about. go the 2JZ!!!
Edited by linxus40
https://www.sau.com.au/forums/topic/139875-the-aristo-is-mine/
pics here
Hey Jason! Good to see your beast on the road.
LOL might have to convince Craig to come by in his Aristo to take a pic next to yours. He loves teh Aristo's (as do most of the boys at J-Spec). The VIPBOY Aristoid is identical to yours except I think you've got factory cupholders and a sunroof.
That's nice and clean - I was going to get one of these, but decided on the Cosmo instead.
So tell us - how does it go ?? Give us the low down and review !
Looking forward to hearing about it.
Are you going to mod it ??
Cheers,
^^^^^^ yes basically the aristo is the 2JZGTE a twin turbo 3.0litre.
the chaser depending on age is a 2.5litre twin turbo(older models) or the VVTi single turbo (95 onwards i think). very nice cars. excellently set up for drift as standard.
Bollocks. Chasers are just run of the mill family sedans. They'll drift with some suspension work.
Chasers got a 1JZ from memory, wheras Aristo's got the 2JZ (incidentally Aristo's came with the 2JZ BEFORE the supra's :)... so in fact the Supra is a 2 door coupe with an Aristo engine if you wanna get picky).
i was just saying what i've read and heard. tehy are popular with younger guys and gals in japan who are getting into drifting. cause they have the balls to get sideways and stay out there. tricked up suspension helps even more.
theres actually a variety of chaser like cars made by toyota. the Mark II, the chaser, the tourver V and the Grande. the grande came with N/A 2 JZ the other came with 1JZ twinturbo or single turbo.
Chaser's come in manual whereas Aristo's don't, and I think Chaser's weigh a good couple of hundred kg less than the Aristo (but don't quote me) I also think you can get an AWD Aristo.. very rare and mighty heavy at something in the region of 1900kg o_0
That aristo wouldnt happen to be the one running on the dyno at my bro's shop last saturday was it?
nah hasnt been dynoed yet.
all up cost about 17K and thats for a 95 model that is very clean with a true 77K kms, sunroof, factory cruise controll and 12 stacker cd player.
just did about 200k's in it today and i must say it has some balls in stock form. with an exhaust and some more boost this thing is going to tear it up hardcore
Edited by linxus40
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
