  • Replies 55
Rather than stop @ eng oil, here's a run down on what I've been using & the links to each one (I hope?).
Engine: Motul 300V (10W/40 mostly)
http://www.motul.com/redirectuk.asp?N=1.06.02.01
If 300V is good enough for NISMO & MUGEN to use it then it's good enough for me :D
G/box: Castrol VMX80
http://www.castrol.com.au/castrol_001/prod...rans_index.html
Diff': Redline Shockproof "Superlight" http://www.redlineoil.com/redlineoil/spgoti.htm
Brake fluid: Motul RBF 600
http://www.motul.com/redirectuk.asp?N=1.06.06.01
Brake pads: EBC Greenstuff
http://www.ebcbrakes.com.au/green.htm
As Motul is a French based company the English translation on their website is a tad average :)
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/3/#findComment-19011
Originally posted by adam 32
yeh mobil 1 5W50 is too thin for a worn engine, redline or agip 10W40 would be better
im surprised to hear alot of you using mobil 1, ive been told by quite a few people to stay clear of it - not good quality etc...
As I said this is NOT the stuff you buy at Mobil servos or Kmart, it's a different product. I've heard not good stuff about the regular Mobil 1.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/3/#findComment-19710
I thought I better add my opinions on Oils.
The biggest problem we all face is we have NO idea what happened before we all got these cars. The most critcial time in a motors life IS the 1st 0 to 20000 kays. Did he/she run it in properly or was it thrashed,,,,did it get regular(5000kay) oil changes or when they got around to it.
I think some of you guys are chucking away good hard earned money on oils that are just not needed. Sure top quality Synthetics oils are the best thing man has invented for the Internal Combustion Engine,,,,buts it not real good for most of us because we don't know what happened before we bought them and sometimes its just plain old "to slippery".
You guy's are gonna kill me,,,but I use Castrol Para-Synthetic oil,,,,. Only because it only stays in there for 5000kays and it has good,,,not great detergent qualities. At 70000 plus kays you don't wanna start cleaning every bit of sludge and build up out of the motor or you'll end up with one noisey Mutha.
Shell,,,, stick with the Mobil 1 you are using,,,changing oils is never a good thing.
Neil.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/3/#findComment-25511
OK, OK....
Can someone answer this question. If an oil has good temperature stability, is it the better oil?
Oil's making 5kw or more to me means nothing as it has to do the basic function, protect the motor.
My thinking is that if it holds temperature better, it has less wear and tear on the motor, thus is the better oil.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/3/#findComment-25522
SIlver-Arrowz,
I think your on to something there. Some oils tend to loose the plot when the temps get high.
NDR,
You've got a good point there. If the motor is crap to begin with, then the type of oil that you use isn't going to fix it, but it might stop it from getting worse.
I was lucky when I got mine. I found the service history book under the seat, it had all the factory services done before the KM's were up, car chassis and motor numbers are the same too (thank god...).
J
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/3/#findComment-25627
I agree with you ndr. There's not much point putting expensive super low viscosity oil in a tired & worn motor, just as silly as putting low grade 25W60 into a healthy close tolerance twin cam turbo engine.
The grade of oil should be chosen based on manufacturers spec's, climate/temp, age/condition of the engine, & the intended use of the engine.
In a healthy engine you want oil that resists high temperature charring & maintains its viscosity. Oil that doesn't hold up under high temperature will lose viscosity & cause a drop in oil pressure, it's also more likely to burn, or carbonize.
In a performance application the better your oil holds up under high temp' the better it's protecting the engine internals. 5000k of "enthusiastic" driving "can" include a lot of high oil temp's, a track session is a perfect example, hence oil coolers to keep the oil temp under control. A quality performance proven oil is worth the extra $$$ if you’re keen to drive enthusiastically from time to time ;)
Have a chat with the pit crew on a race team (any form of racing) & see what oil they use? & how often they change it?
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/3/#findComment-25965
  • 1 year later...
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
