Thanks mate :down:
Yeah i guess im not as old as some but still feel like i should have done it a few years earlier.
Anyway, today at work i finally managed to remove a sleeve that was halting the final disassembly of my gearbox. I was very pleased to get the sleeve off the counter shaft which enabled me to remove both the main shaft and counter shafts from the sandwich plate. So now i will organise a new sleeve (had to cut it) and all new seals and bearings. I planned to sand blast the gearbox case to freshen it up but to make the transfer case match it will have to get the same treatment. The problem is that i didnt really want to pull the transfer case apart. It wouldnt be a bad idea to check it all out and make sure everything is within spec but of course that will take more time. The other option is to paint the gearbox case and the transfer case without disassembling it. It would look fine but im a bit concerned about the durability of the paint. Thats the advantage to sand blasting it all.
Today after work i finally fitted the turbo oil return hoses, complete with new heat insulation cloth. Theres a number of similar small jobs that im trying to get finished up.
No progress pics at this stage but i will get some soon.
I was thinking to ask you that, now i dont have to :bunny: Thanks for the reply Brendan. Did you use an etch primer on the alloy case before the top coat? All the alloy i've painted so far ive primed first for a little better adhesion. Im open to ideas with this one :)
Hey Duncan, thanks for your input :blink: Maybe i should just go with the painting idea. I am thinking to strip down the transfer case now so the sand blasting is an option... I think i'll wait and see closer to the time and make my decision then.
I called about a rebuild kit for the gearbox today. A place in sydney can sell me a full kit for $330. Im not sure if that was trade, as i mentioned where i worked but didnt ask specifically for a trade price. They said the FS5R30 uses the same kit as the RB30 powered Patrol. Can anyone confirm?
What is FS5R30, is it the gearbox code? I am certain that you can only use and rb26 specific gearbox rebuild kit, in comes with the bearings, series 3/r33 synchros etc. still all bolts into the r32 casing though. If you are talking to sydney about it, call award gearboxes in Rydalmere
I was thinking to ask you that, now i dont have to :D Thanks for the reply Brendan. Did you use an etch primer on the alloy case before the top coat? All the alloy i've painted so far ive primed first for a little better adhesion. Im open to ideas with this one :)
I was lucky in that the casing had no guts so was easy to move around. I started with a degrease, and then had it acid dipped as well. Whether this helped or not I'm not sure. I gave it a good hit with the prepsol, then went at it with the VHT Nu-Cast Engine Enamel in Cast Aluminium (SP995) colour. I think I did 2-3 coats of that, making sure I'd masked up the relevant surfaces that needed protecting. Then I hit it with a couple of coats of VHT Brake, Caliper, Drum and Rotor Paint in Clear (SP730). I used the same process on the diff cover too.
As you can see from these pics, it came it well with a nice smooth surface which has so far made it very easy to clean:
http://www.sillbeer.com/images/driveline/b...fter-fitted.jpg (close up sort of)
http://www.sillbeer.com/images/engine/s13-...ox-drveside.jpg
In hind sight, I should have hit the top part of the sump as well to match the two colours up.
Cheers
Brendan
Sorry i somehow missed the idea of powdercoating it. Thats always an option isnt it. Only problem is extra expense and will it match the rest of the build?
Yeah, FS5R30A is the model of the gearbox. Im yet to fully inspect it. So im not sure if i will need any new syncros yet. Thanks for the input on the rebuild kit. Only reason i called those guys was because i heard they did good prices, and they do. However now im not certain they have what im after. Anyone know of a Brisbane based shop that can supply me with well priced gearbox parts to suit? If not i'll try Award.
Cheers
Brendan
Thanks for your reply Brendan. I would be quite happy with a finish similar to that. Although i have used a darker grey metallic on my rear diff inspection cover so if i do go with the painting option i might use that color instead and then follow up with the clear coat. It would be something different anyway :O Now i have to decide what i want to do.
When I had my reverse gear lockout problem, the guys at All About Gearboxes at Greenacre mentioned how just about all the Nissan gearboxes are the same and said something about my GTR having the same gearbox as a Patrol?
This post isn't much help (it was over two years back). But thought I'd share that I'd heard about compatibility between Nissan boxes too.
FWIW
No its all useful, and i thankyou for giving me your input :O
By the way the color i planned to perhaps use on my gearbox casing and transfer is the same as i've used on the exhaust manifold covers etc.
Edited by Godzilla32
will it match? that will depend on the colour choices the coater has, looks like a stamped steel or high metallic gun metal.
will cost a bit more than paint yes, but you wouldnt need to worry as much as normal paint as to whether it will last :ermm:
just an option is all,
Hey Nick. How are ya? Yeh its been difficult at times but im quite patient :D I just have to remind myself that i'll have a sweet GTR by the end of it all. I was actually reading through the thread last night. I had forgotten how much work i have put into this project. In the next few months the engine will be back in, which will allow me to pretty much complete everything else in the engine bay. That will give me plenty to do!
I'd like to catch up for a beer, let me know when your here :(
Deren
Got into work today for a few hours and completely disassembled the rest of the gearbox. It all went smoothly which was good for a change :happy: I've sorted out all the gearsets and wired them up together to minimise confusion during assembly. I put a few parts through the industrial hot washer at work and began the cleaning/inspection process. A couple of the gears got small disassembly chips, but they will be fine after a bit of polishing/grinding. Besides that it looks good so far, so hopefully i'll just replace all the bearings and seals. I need to find a gearbox part supplier in Brisbane that is familiar with the FS5R30A box from the R32 GTR. Can anyone help me out? Nissan quoted me a reasonable $430 for a full rebuild kit. Compared to the kit for $330 from Australian Trans in sydney thats pretty good. Im not sure whether or not the aftermarket kit from sydney is the right one either. So a local supplier would be great if anyone knows of one??
Sorry i forgot to take pics at work.
Deren
Good stuff Deren. Since I'm pretty crippled atm I'll have to bring my gearbox from the racecar over for a reco mate, once it comes out. Cash job of course :down:. A top quality tuner smashed the syncros in 3-4 and at oil change the bits came out the bottom. I drive it like a race box anyway but it would be nice not to have a crunch when I forget to shift hard.
Hey there Geoff :down: How did he manage to stuff the syncros doing a tune? Or was this during a drive?
You want me to rebuild it for you?? I could take a look at it if thats what u mean. Always up for extra cash.
During the drive after the tune mate. Ham fisted was all it was. Down in Vic too but since I'll be selling it later I'll need to sort the box out.
First priority will be running it at the Nissan sprints at QR with Time Attack, then I'll work on getting the box out for you to earn some bucks from me.
    • Here's a boring history lesson on number plates People want illegal spacing to make their plate more readable, if mine was J2X BK, anyone who knows about the car would see that its spelling JZX. Years ago third party plate manufacturers could alter the text to make it look like something else, nowadays the computer software is locks that ability (well, ours does at work) Up until 2001 the first letter of a number plate represented the year of the vehicle, for example A would be 1983. (pre 1983, the format was backwards, so the year letter was on the end). Followed by 3 random numbers and 3 random letters. Things started to get complicated at the end of the 90s where T and V were 1999, W and X were 2000 and Y was early 2001. From 2001 they introduced a new 'layout' where the first two characters are letters, this represented where that vehicle was first registered in the country. The letters corrosponded to a region in the country. Some regions had a large number of codes, where as some only had a couple (despite being large in physical land size) Next are 2 numbers to indicate 2000s. So it went from: Y (March 1999 > Aug 2000) 51 (Sept 2001 > Feb 2002) 02 (March 2002 > Aug 2002) 52 (Sept 2002 > Feb 2003) etc etc When the 2010s got here, the numbers changed again, going up by tens 10 (March 2010 > Aug 2010) 60 (Sept 2010 > Feb 2011) When the 2020s arrived it went to 20 (March 2020 > Aug 2020) 70 (Sept 2020 > Feb 2021) etc As for personalised plates, you're not allowed a registration that makes the vehicle look newer. Take my 110 for example, its a 2004 car so I can have any available plate upto 04. I can't have a 54 because it was manufactured in August 2004. Which allows me to have a J plate, because its older (if that makes sense)
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
