  • Replies 111
So what's the latest? Saw that Cressida boat running last Friday, only saw one run but it looked like he hit the brakes hard and a mediocre launch? Still did a low 10 - had it already run a 9 and would be booted if dipped into the 9's again?
Any word on Dirt hitting the track?
gee, when did i run a nine? i must have been asleep when that happened.
its run 13 10.00 at 146 mph but i havent run a nine yet.
on the pass you saw i had to get off it twice in second gear and then when it tyre shook again in third i got off it and ran a 10.2 at 109 mph 115.8 mph to half track. some 2 mph up at half track on when i went 146mph. we had the car for a 9.4xx at 150.8mph, just we didnt have the track to do it. cant wait to wind more boost into it. :cheers:
Hah, I got there late and that was the only run I saw you do. Was pretty impressive, looked like a very very easy 9 second pass *if* there was no backing off. I had thought you might have been pedaling it just to stay in the 10's if you didn't have the rest of the ANDRA gear to be teched for 9.99+. Still, making a buttload more power than last year. No trans problems this time?
on the pass you saw i had to get off it twice in second gear and then when it tyre shook again in third i got off it and ran a 10.2 at 109 mph 115.8 mph to half track. some 2 mph up at half track on when i went 146mph. we had the car for a 9.4xx at 150.8mph, just we didnt have the track to do it. cant wait to wind more boost into it. :thumbsup:
Very impressive. :)
What tyres are you using now?
had to pedal it as te track was shit and didnt want to put the car into the wall.
the pass you saw it tyre shook in second and third gear.
it ran 115 to half track an 109 full track. so yes there was an easy mid nine if the track was there.
the car is teched and has the chute on.
as for the box, it needs a billett converter, its slipping badly in third gear. tyres are still mickey t street radials.
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
