after reading a mighty good thread on small singles or even big singles on gtrs i decided to stay low mount twin! it was going to cost well over my budget anyway?
i am only looking for around 300-320awkw this is what i think ill need,if there is anything missing or i have something there that isnt needed would be great if yous could let me no?
pfc+hand controller
550cc injectors
z32 afm+plugs
front pipes(just jap or should i get hks)
cam 260 duration 9.1 lift
cam gears
new cooler core
fuel reg
oil cooler and relocater
now with turbos this is where i would have to be careful so not to blow the budget
so ive seen some r32 gtr n1 spec turbos for about $1200 what are these thinngs like if someone could shed some light
gt-ss bit pricy but would the best option
gt2860r with either -5-7 not sure what these are like b ut sound good for $2700
so any help would be greatfully appreciated
regards kane
https://www.sau.com.au/forums/topic/140315-new-setup/
  • Replies 281
pfc+hand controller
550cc injectors
z32 afm+plugs
cam gears
new cooler core
fuel reg
regards kane
GT-SS's pricey?
The Aussie dollar buys over 90 Yen at the moment so its an awesome time to buy. The GT-SS complete kit brand new should cost you a touch over $3k delivered.
They will be more responsive than the 2860's and will easily accomplish the power you want.
My GTR is producing 320awkw on a safe tune with them at the moment.
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2614346
517's arent as good as the GT-SS mate. Dont come close.
GT-SS comes in the kit remember, so everything you need.
You'll need to change the dumps though, the stock ones will hurt.
Stock manifolds are quite ok however
Dont get R32 N1's, they are shocking. There is a very good reason they are so cheap :P
Old design & shocking/poor response.
Its worth the extra $1500 for decent turbos.
everything else you have seems about right, except you want Nismo AFM's, not Z32's.
Otherwise you have to change intake piping and thats a mission if your on budget
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2614498
thanks alot mate, wasnt to sure of the r32 gtr n1 turbos.
about those air flow metres where could i find those?will i have to change plugs with them?
hks dumps be fine from nengun
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2614655
Boost controller, replace coils, while you are doing large upgrades...........
...replace oil pump , water pump and timing belt....get the bearings and bolts changed at the same time though.
Then after it has cost you $5000+ :) to install your $7000 :P dollars of parts you will need to upgrade
or pay some attention to the brakes and suspension......and after $3000 :O of this....
.....you will then need some rims and sticky rubber so you can get a 1/4 mile result...this would cost about
$4000. :O And you haven't finished yet.
Believe me ....cause these are the figures you are facing.....
If you are worried about $3000 wait until you finish your upgrades. :)
As far as the -5(2530) turbo's.....they are the best choice for 320AWKW's and you have to have the Poncams to get this figure.
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618590
The 2530 is NOT the best choice for 320rwkw
They are the BAD choice
We have already established that earlier on
And i bet i can get over 300rwkw with the stock cams, thats my aim with the GT-SS, just a cam gear :)
He has stated he wants 320AWKW's not rear wheel.
I have the 2530's and am at 260AWKW's...I need Poncams to get me to 320AWKWS.
Or have I mis-understood his intentions?
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618633
Can i be your mechanic :) You seem to enjoy overkill...nothing really wrong with what you are suggesting i suppose...but id like to think that a GTR owner that is about to do these sorts of mods has a properly serviced car....so no need for new water/oil pumps, timign belts, coils etc etc
What boost have you up your thing for only 260kws with 2530s ?
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618686
If you read the..........engine failure thread.... you will be suprised on how many people get into trouble
because they believed the odometer reading in there car.... :)
When you are searching for more horses, as stated many times you need the mods and then you need the supporting mods. If their is any doubt in your mind ,that, their could be some issues with the current oil pump or water pump, you need to fix this first.
The last thing I would hate is to recommend something when I do not know the state of his vehicle.
The last thing he needs is to spend money...and then blow his motor...because of a timing belt , bearing or bolt
due to poor maintence.
Roy...my boost is at 1.3 bar and I have a 7500RPM cut out.This gives me 330RWKWS..
Poncams I am hoping will get me to 300AWKWS :P
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618726
AWKW and RWKW is the same thing... so im not sure how your confusing the intentions here.
I dont think you realise there is absolutely no difference between the two.
Dirtgarage tested AW & AW it, 1kw difference which is nothing but dyno variance at its best.
If you have 260 @ the tyres and your being told you need poncams for 320, then your mech IMO does not know what they are doing, time to have a chat with them or find another.
A stock turbo's GTR will pretty much make 260 @ the tyres. Let alone putting bigger turbos on it.
As stated, 2530's will net you around 370rwkw. They are not the turbo for 320rwkw/awkw or whatever other 4 letters you can think of
This information is all over the forum in a dozen different threads.
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618739
i had in mind the oil pump,but as for timing belt water pump(n1) bearings bolts all done about 5k ago.... suspension ill leave for now,breaks aint to bad...
also i had poncams and gears as my choice already 260 9.1 lift so on... i think the gtss will do fine for what i want. and also the i alaways thiught awkw was the a rwkw 2..thanks for info guys keep it coming
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618803
Poncams I am hoping will get me to 300AWKWS :)
Again point taken...but what your suggesting isnt a common denominator. You dont have to do what you have posted for it to be reliable, provided you know the history of the car, which i would say most owners know, or mechanics can inspect. But agree, if you dont know the condition of the car then hold off on the mods until you have owned it for a while
https://www.sau.com.au/forums/topic/140315-new-setup/#findComment-2618804
