  • Replies 281
after reading a mighty good thread on small singles or even big singles on gtrs i decided to stay low mount twin! it was going to cost well over my budget anyway?
i am only looking for around 300-320awkw this is what i think ill need,if there is anything missing or i have something there that isnt needed would be great if yous could let me no?
pfc+hand controller
550cc injectors
z32 afm+plugs
front pipes(just jap or should i get hks)
cam 260 duration 9.1 lift
cam gears
new cooler core
fuel reg
oil cooler and relocater
now with turbos this is where i would have to be careful so not to blow the budget
so ive seen some r32 gtr n1 spec turbos for about $1200 what are these thinngs like if someone could shed some light
gt-ss bit pricy but would the best option
gt2860r with either -5-7 not sure what these are like b ut sound good for $2700
so any help would be greatfully appreciated
regards kane
Howdy Kane GT-SS from nengun http://www.nengun.com/forced-induction/2 only $2650 and you get all the good studs gasket sets . Thats the path I,m taking Never had any problems with Nengun good exchange rate at the moment .They cost over double here too many greedy people here.
Delivery cost is neglible.
good luck with it
ike
good luck with it
ike
Add GST and import duties if picked up by customs.... more than $3k....
was all ready to install the turbos 2day until i seen the blooody justjap dumps have a massive whole for the o2 sensor,so i pulled the reducers out the stock dumps to find they also dont fit?
does anyone no if the 33/34 gtr o2 sensors are bigger and they may have sent the wrong dumps? i will ring tomorrow and ask however..
what ya get for buying cheaper parts.should have bought the hks ones i liked from nengun...
A user on the UK GTR tried this, his user name was T.F.S.
with the ignition timing done my next step is to look at the fuelling.....the car has a wideband fitted now so fuelling is displayed in the cockpit, just checking it at idle told me that this engine was running very rich....as the engine warmed up it went as rich as 10.1:1 and it would net go into closed loop
(more infomation on fuelling in www.max-boost.co.uk)
the first step in this instance is to check the lambda sensors, the two oxygen sensors on the exhaust side provide critical infomation to the ECU for fuelling in "closed loop" operation, these sensors can be checked with a multimeter at tickover....output from the siginal wire on the sensor lead should be in the region of 0.6-0.9 (roughly) if it is alive
both of mine seemed totally dead, no output at all...the logical explaination for this is faulty sensors but it turned out that there was more to this.....
R32 came with 24 pin chip ECU and small lambda sensors with red siginal wires, R33 came with 14 pin chip ECU and larger bosch lambda sensors with black siginal wires
the looms also have slight differences with the lanbda siginal and heater wires
mine has a 32 ECU with 33 sensors so i simply rewired the sensors so that the siginal wire matched up with the ECU side
with these 33 sensors now working on the 32 ECU they were changed for new versions (£60 each from justlambda.co.uk) and run fine going by the output from my wideband
Make of it what you will.
Are you running the Power FC? If so, just disable the closed loop feedback and run with bungs!
If you get eager to optimize fuel economy (or if you guys need O2 sensors to avoid getting defected) you can fit O2 sensors later.
Can't wait to hear how she goes!
Dan
Kane
Sounds like you got the rebuild blues.
Doing the same with mine. Custom 3" dumps/front pipes are the hold up. W/E 16/17 Feb should see them done (again) and the engine off the bench and back in the car.
Really curious as to how the cars compare as my mods are pretty well the same - 2860-5, PFC (+EBC), pipes, 700cc inj, fuel pump, adj cam gears, sump baffle, oil cooler, JB clutch, timing belt. Same sort of target rwhp.
As you have no doubt found, it all adds up really quickly.
Stick with it and keep us updated.
Cheers
thanks alot for the feed back fellas.
sure do have rebiuld blues,hold ups everywhere.but hey all makes things worth waiting for at the end?
whats involved in disabling the close loop and what sort of fuel economy will i have? as in does it make a huge diff? did come with bungs yes?
thanks again and i cant wait for the thing to me on the road.
simple dont do it, it's not worth it, trust me a little time delay now you'll save yourself alot down the road. Get the O2 sensors in properly or you'll pay for it 10 fold down the road.
my 2c
ps i run 500rwhp+ and still maintain 500km per tank normal driving as do many of the well tune gtr's in WA the close loop system helps trust me.
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
