Hi just purchased my gtr not long ago, and after talking to a couple people I have been told that with the r32's it is good to fill the engine with an extra litre of oil?
Just wondering if any of you guys had heard of doing this, and what are the reasons behind it?
Cheers,
Dave
https://www.sau.com.au/forums/topic/140613-r32-gtr-extra-litre-of-oil/
i have heard of people doing this on track days to decrease the chance of oil starvation from cornering,braking etc
apparently works a charm but is a bit messy via lots of blow-by i.e oil catch can will prob have to be emptied afterwards
cant see it being very neccessary for everyday driving
never had an oil problem with my gtr but oil systems are known as a weak point due to age
Hope that helps
RellikZephyr
The internal pressure of the motor.
I personally wouldnt be putting in a whole litre of oil in extra, a whole litre of oil is alot, it may not look like alot but its a f**kload extra. Its never good to overfill, unless of course what was mentioned before about track days etc.
Yer internal pressure of the motor....
I was thinking it might put strain on the seals that's all. :P I mean i definately understand the reason behind the added 1ltr during a track day to stop oil starvation, but then im guessing the thrash around the track would add to heat=expansion=more pressure=strain on seals/gasket=leaky seals.
Wouldnt a better way of stopping the problem be to install a High Energy sump for that extra capacity rather than a kind of "band-aid fix"???
I dunno...im just guessing here. :laugh:
oh yes the baffle is far better option but an extra litre of oil is a lot cheaper im guessing thats why people do it
i will be putting a Tomei Baffle in my Gtr but its not as cheap as you might hope 200 odd for baffle then fitting requires removing sump and as you may remember the front diff is part of the sump in Gtr's
lots o fun
oh well like gtrchick said if your gonna do something may aswell do it properly
RellikZephyr
...im just guessing here. :(
That's pretty obvious.
The oil pressure is a measure of the resistance of the oil to flow through the galleries of the engine. It is independent of oil volume - otherwise, the oil pressure would vary as the oil level varies between the lo and hi marks on the dipstick.
Oil pressure is related to the viscosity of the oil, which is basically relative to temperature - cold oil runs higher pressure than hot oil.
I heard it off a guy that had the engine recently rebuilt by ben at racepace, he said ben said that in a straight six engine it's good to overfill because under strong acceleration the oil moves towards the back of the engine and can starve the cylinders towards the front?
what do you guys think?
ahhk k ...well i was almost kinda there....sortof :(
hehehe
I knew that temp had an effect on pressure of the oil, i just forgot to carry the 1 when over calculating. :)
out of curiosity.. how much oil do you gyus put in the GTR?. i usually jus put the whol 5L bottle of elf excellium 10w50 in. but now ive got a oil filter relocator and the lines to the filter is about 50cm or so lol.
should i be putting in at least 5.5L?
I run the extra litre in my 32 as when i used to accelerate hard in first and second my oil press would momentarily drop off ! With the extra litre ive never a problem since and its been like that for couple of years now. :)
do you have an oil catch can? Does it get filled with oil from overflowing? or do you have any trouble with the extra oil in the system?
RellikZephyr
RellikZephyr
Yes i do use a catch can and it has never filled up. The most i ever get out of it is about 100mls after doing five or six runs down the quarter ! It was much the same after doing about ten laps of QLD raceway. I do have a oil filter relocator and oil cooler so that might take up a bit extra oil. Ive had no probs with with it at all and i know a few others that do it as well with no probs. Like i said, mines been running like this for a couple of years now and done over 30,000 kms so i think if anything was going to go wrong it would have by now. :laugh:
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
