Hi
I just had a intercooler installed and im noticing sum problems. While I drive if I go to give it a bit sometimes it'll react like it's suppose to but sometimes the engine will cut out and only the turbo opens and then the whole car jerks 2 or 4 times with the engine kicking back in and then it drives normal or it will happen while im just cruising and I also get no feedback from the accelerator peddle. It's starting to bother and worry me so any help is greatly appreciated. This has also happened once or twice before it was installed so is it the intercooler or something else????????
https://www.sau.com.au/forums/topic/140794-engine-trouble/
how much boost are you running? what other mods does the car have?
Just an aftermarket Kakikomoto exhaust system and HKS pod filter, Blitz Boost gauge and turbo timer. The boost is running standard. You know of any ways of fixing it? Should I upgrade to a new ECU as I will be doing this eventually or would I basically have similiar problems?
https://www.sau.com.au/forums/topic/140794-engine-trouble/#findComment-2623198
I've checked the vacuum hose and i couldn't see anything wrong. Is it possible that maybe one of the hose clamps aren't on tight enough and a bit of air is being leaked out or something cause they don't have any slits in either. Also does anyone know where to get a proper car manual for a 95 R33 GTST Skyline?
https://www.sau.com.au/forums/topic/140794-engine-trouble/#findComment-2624657
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
