Hey guyz,
i noticed that my climate control is behaving in a very "extreme" manner
when turned to 18degrees (the lowest) it becomes damn cold (@ 18 i presume) and when i increase the temp
to 19degrees it becomes damn hot...like it's at it's hottest...
an electrician told me that it could be my aircon server motor's fault and it requires 2hours of labour just to check it out ...anyone have any good recommendations on what to do?
chock
https://www.sau.com.au/forums/topic/140816-aircon-system/
Hey guyz,
chock
sounds like your mechanic wants to drain your pocket..
In most cases it's your in cabin temperature sensor. Borrow someone's and see if that fixes the problem.
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2624659
  • 5 weeks later...
I too am having problems with my climate control, it read -30deg for the ambient temp, thinking it was the unit itself that was dodgy I swapped for a spare I had and still reading -30deg. I'm thinking this might explain why I can't get the aircon to work, it just blows really hot air all the time as it thinks it's 30 degrees below zero in the car..
So where is this in-cabin temperature sensor located?
Cheers.
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2708745
I've had the same problem for ages, it will blow hot hot air at any temp setting. I just use the 'FC' function (hold down the cold button for 3 seconds at 18 degrees) on the aircon to get cold air when I need it..... stuff the climate control, I either want it hot, or cold, there is no inbetween :laugh:
If it starts to only blow hot air in any mode, then I'll have to do something about it.
Fixxxer
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2718950
to the right of the ashtray. a couple of little vent holes on the front of the panel and the sensor is mounted in behind.
Ohhh.. that thing I discovered when I put my stereo in that isn't connected.. I thought it may have been like a mic for an carphone system or something from japan.. pretty sure the wires have been chopped - guess I need to find a wiring diagram and start fishing around behind the dash :thumbsdow
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2720111
i had the same issues. i just removed the faulty sensor (Left side of dash, under windscreen) and replaced it with a resistor that is the right impedence, to make the climate control think that the intake temp is 30deg.
Edited by R324DR
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2720175
So when you turn the climate control on it just cranks the aircon?
Are replacement sensors hard/expensive to get?
Got any specs on the various sensors? says all of mine are shagged :P
Sory for all the questions.. my mrs wants the aircon working :P
https://www.sau.com.au/forums/topic/140816-aircon-system/#findComment-2722614
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
