yeh i have done mine... awsome right up!
i forgot the bottom o-rings :P hydro locked a cyl. hahaa..
but when that was doen was awsome... now running 250.1rwkw in my 32 rb25 :P
cheers again!
  • 3 weeks later...
  • 2 months later...
Hey there guys, Thanks Alan i found this really important. But i thought i would make people aware of this, Be VERY CAREFULL when trying to remove the fuel rail and injectors out. And look at the end of the injector and make sure all off the 4 prongs or claws on the orange pintle cap are attached. Because i am currently sourcing the 6 pintle caps and there not easy to chase down because they are so wanted :starwars:
Hope this helps Cheers Rob
  • 7 months later...
Great DYI mate
Installed my Tomei 555cc today which replaced the std R33 GTST injectors.
I didnt remove the AAC, didnt get in the way at all for me. nor did the FMIC piping.
For cracking the injector cap screws i used multi grips.
To get the injector out of the rail i used a flat head screw driver and slipped it under the injector plug then twisted the driver to lever it out.
when i changed the power fc injector config, i used the following. Old Injector CC / New injector CC x 120 = 82
my power fc was configured at 120% for each injector...not sure why it was set like this but the above achieved a nice idle. i did actually test 66% based on the x100 calculation also...and idle went to hell...
  • 5 weeks later...
  • 1 year later...
  • 4 months later...
  • 5 months later...
no...it will probably start up and idle ok but soon as you put it under load it pretty much floods it..then plugs will foul then it all falls apart..i tried it once, got around the block but barely made it home..lol
but if you have access to your ecu just find out how to change settings..
  • 5 months later...
really good writeup. i have a powerfc waiting to be installed in my series 2 gtst but i wanted to upgrade injectors first two quick questions..
1; will injectors give me much more power once installed and tuned with the power fc
2;where is the best place to get hold of some injectors and what size is good when chasing 300 to 350 hp?
cheers
  • 1 year later...
Hey guys, know this is a pretty old post, but need to know if there are any major differences when doing this for an rb20det ?
any steps added? important things to note?
anything will help, cheers
  • 2 years later...
  • 4 years later...
14 minutes ago, SKY5HW said:
Nice write up and presentation, my question is will we need to dyno the car once everything is fitted back?
If you change to different injectors  it needs to be tuned.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
