I was looking at running a GT30R, but looking closely at the results there arent many ppl making early 300rwkws with them. Typically 280-290rwkws with a good lung full of boost. So not much headroom for pumping a few extra psi to get anpother 30-40rwkws out if it for ballpar 340rwks.
So from there GT30R, how much difference in driveability is there to a GT35R? Im hoping to get around 290-300rwkws from 16psi, with the occasional adventure to around 22psi where i would hope to net 340-350rwkws on Optimax.
Needs to be a single, and needs to be T3 flanged. Since i already run a Greddy setup was also considering the TD06SH-25G.
Not overly concerned about lag, as long as it makes strong power from 4,500rpm to 8,500rpm. (4,500rpm +200rwkws)
Speaking Garret talk, i suppose im curious to know if the 3240/3540 are good things etc, or can the GT30R be leaned on to credibly give the numbers i want?
https://www.sau.com.au/forums/topic/140989-turbo-reasonably-effecient-at-16psi/
  • Replies 41
Posted Images
16psi on a 2L to make 300rwkw is a hard ask Roy. Its like asking a RB20DE to make 140-150rwkw in naturally aspirated form. The GT35R might do it, but 16psi is not much flow to work with unless you have big cams/porting etc. You are better off leaning on the GT30R to reach your goals rather than oversizing the turbo just for the 'lower boost' mentality. A GT35R is a huge thing for a 2L and the transient response even on boost will be less than desirable. Remember 300rwkw is 300rwkw, no matter what the boost; the strain on the motor is the essentially same really.
EDIT - of course this is assuming you have an RB20DET...
Edited by Busky2k
Ye, but they are 3ltr man... you are 2ltr.
You need more boost, the SOHC guys have ported heads/cams etc.
So its not something comparable.
And they are using more than 15/16psi for thier 300rwkw, closer to 20
You'll need 20+ psi to get close to 300. I had 270 on ~17psi
Oh... the latest crack pot idea you had eh? hehe :(
i cant remember, it had the biggest wheel offering at the time for the 600hp variant.
there were 500 and 550 also... wasnt those though :rofl:
btw - your weak as p|ss, going home @ 3am
Yes a big ask from a 2L six . How far are you prepared to go/spent to get it there Roy ? Probably needs a really flying head and healthy cams to get there . Its fair to assume that the GTS-R's exhaust manifold is good considering it was designed for the Grp A RB20 .
Does anyone know what spec the GMS R31's ran and what sort of power they made ?
Cheers A .
Ive got a pretty good idea of the Gibson cars since i know a guy that has just restored one and has spare Gibson blocks etc laying around. He is one of the little birdies in my ear saying that the std RB20 is pretty strong...hence me beign pretty comfortable about running 1.5bar for a few laps at Sandown :(
Its not a 2L either. Will be running 26 crank, Eagle 26 rods, Apexi cams and cleaned up head. :rofl:
Hmmm , well Watson we'd probably have doubts about using a hydraulic head to 8.5k so the evil Moriati may have the gun head in the wings ...
Whats with the negative waves....why cant you just dif what a beautiful day it is :laugh:
And im not that fussed about the std lifters. With the std springs at the moment im pulling 8,500-8,800rpm. I even gave it a hit at 1.5bar and it didnt seem to have any head problems. I hope with better springs and still only mild lift cams i can still get away with the hydraulic lifters. At the end of the day im hoping not to have to rev the new engine as hard as the std RB20...but will if i need to get the drive in the next gear
That said, i am on the lookout for a poor soul that has had dramas with a bottom end letting go and a ruined 26 head. It would be good to get my hands on the valve gear
My understading is 3037 is basically the GT30R
i've still got my 26 bottom end (minus pistons & rods) which made way for an RB30 :laugh:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
