I have a friend of a friend who has a High Flow RB30DET turbo they are trying to offload as they are getting a bigger turbo.
Would that turbo be suitable for the R33 engine as an upgrade with supporting mods...ie PFC FMIC ZORST Boost Pod... ????
If som will it bolt straight on or need some mods to do so ?
He also said it was an XMS high flow..What's that???!!
I searched on here and can't find an occurance of XMS, hopefully getting mixed up with XTR as i think that's GCG ????
Thanks guys.
Birnie
Edited by Birnie
https://www.sau.com.au/forums/topic/141040-rb30et-high-flow-turbo-on-rb25det/
Whoops, i meant the RB30ET off a VL.
Not sure about BB yet but trying to find out.
Apparently high flowed by XMS so if i can find out who they are, i should be able to find out if BB or not.
Can you tell by looking at it from the outside if BB or not?
it will not be ball bearing if it has the rb30et core.
you will need to modify the dump pipe as it has the wastegate flap built into it and the pipe will face the wrong way on the rb25 manifold.
you would need to redrill the oil feed lines which more then likely will not directly bolt up to the et turbocharger core.
it doesn't make economical sense to fit that turbo to your vehicle.
sure it will make the power depending on wheel trim/size but not worth all the stuffing around.
slide makes highflow vg30 turbos (which is the name of the turbo off the vlt). oil and water lines do line up, and as mentioned the banjo bolts and banjo fittings need to be redrilled.
they are good for around 250rwkw with the highflow.
to get more info i'd suggest speaking to Slide.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
