Gauging Interest For A Cruise on Monday 21/4/03
  • Replies 76
I'm in for whatever. Hopefully this happens. I'm busting to actually be able to go to one of these.
I don't care when it is, I'm not working Tuesday. The only thing I care about is not scraping my front bar on the driveway. HAHAHAHAHAHAHA.
Note to self: "Gotta change that front"
BBQ would be great..
Bit further out maybe so its like a 1-2 hour cruise though? Most people have the day off so its probably a good one.
Cardinia dam? Its not far from the dandenongs.. reasonable drive and some good picnic areas. But Jells park is good from what I recall.
Dandenongs? Anywhere in Yarra Valley? for somewhere further out.
ns2500: sure you can come :)
wardest: split your bar completely, wire it up and then you don't care anymore :D Ok i lie, I'm gonna spend the time over the holidays fixing it all up and getting a respray.
OK, so set a time, an area,(Jells Park has a lot of BBQ areas) and a list of what people need to bring, IE: meat, utensils, frisbee, etc. and put it all into the first post of the thread. :D
"OOH, lets all go for a cruise, as long as it's near my house, i don't want to drive too far....."
:DWTF :D
Every time we organise something it has to be in the S.E. suburbs. You ALL want to cruise but don't want to drive your cars. :D
This said, i will still be coming (hopefully). :(
