wow Kermit dude
I just got back yesterday a saw the exhaust u built for me, and wat can i say its absolutley perfect mate
i am 357839495% happy with it and i just wanted to post to thank for all your work mate i really appriecate it
also if anyone is looking to get a custom exhaust built in wa the there is only one places u shud be going and that is kermit engineering, great prices brilliant work and an absolutley great guy aswell
thanks Kermit
Nick
  • Replies 353
Posted Images
  • 2 months later...
Kermit did my R33 in a day, that was only cat-back and my R34 in a day and a half. That was turbo back. That gives you some idea :)
Btw Kermit. I need to come see you. Since putting my kit on, I need to move my muffler a bit further back. My rear bumper is a whole lot chunkier and my muffler is hiding lol. Its making my bumper black as a result. Should be easy enough. I'll give you a call in the near furture :(
Hey Kermit, how long do i have to leave my car with ya?? Me car cant go missing for days as my girl might ask... lol... but if u do need it for a few days, i need to come up with a good reason... :/
um would depend on what job you need doin mate , give us a call or a text and i will let you know
kermit 0422549050
  • 4 weeks later...
Hey mate its almost time for me to upgrade my current xhaust set up on my S15, whick currentle has a mild steel 3.5" kakimoto.
What is it going to cost me to get a 3.5" cat back made up and whats the turn around time like on something like that?
I want to use a 3.5" in/out magnaflow racing mufler.
  • 4 weeks later...
  • 5 months later...
Hey guys , ive been unable to get online for a while and during that time the business has gone through some changes . firstly i will actually be able to get online so i can answer pm's and also offer advice etc through the forum. I am no longer based in Girrawheen but am setting up a temporary workshop in welshpool instead , just off welshpool rd and leach hwy . having a better premises to work out of should allow me to appear more proffessional and offers more security than my previous workshop .
Will supply the workshop address by appointment only as i cannot always be onsite so i am best contacted through calling my mob number .
Although costs will increase slightly you can rest assured that i am still by far the cheapest person to see regarding high quality stainless steel , tig welded exhaust systems and cooler piping etc .
Im currently having a web site set up which will feature some of my previous work . Im hoping that this should be available shortly .
Kermit 0422549050
Kermit 0422549050
Hey Mate
As discussed before, you will be required to become a official SAU trader to continue to advertise/trade on the forums. (We have been asking you for nearly 3 years now :( )
Please PM me for details.
Dan
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
