The compressor only comes in 0.5 a/r, but the turbine comes in either 0.68 or 0.87 a/r.
Lifted from the hksusa site:
HKS GT2835 Pro S - 420 PS Output
COMPRESSOR:
-Wheel- 56 Trim - 53.1 Inducer / 71.1 Major
-Housing- 100 Inlet / 50 Outlet - 0.50 A/R
TURBINE:
-Wheel- 84 Trim - 56.5 Major / 51.8 Exducer
-Housing- T3 inlet / Outlet spec:
Internal GT-Pro; 0.68, 0.87 A/R
This might help:
Grepin,
You also had a 0.87 rear housing for the HKS2835proS, did you trial it?
If so what was the reason that you went with the 0.68 one instead?
I would have thought that the 0.87 rear would have provided more power - easier breathing than the 0.68, but I see you are selling the 0.87.
Interested to hear your findings.
Ans reply:
Basically as I am pushing over 20 psi and making 300rwkw the turbo cant hold boost up top. I thought the larger ar housing might help but still dropped boost. Yes it did give me an extra 15 rwkw with a little loss mid range. I find the car too much of a weapon to drive at 320rwkw. I had to decide which housing to sell and considering I prefer circuit type driving I decided the larger housing. Especially since our drag strip is down.
