Hi Guys,
After reading around the forums and trying to search (for some reason it gives an error) about BOV(s) and becoming more confused than ever I have to ask this question. I have a fairly stock R32 GTR, it has aftermarket air filters as the only mod to the engine. After recently taking my car to a mechanic and discussing future turbo upgrade options I asked if getting a BOV or BOV(s) would prolong the life of the stock turbos on there. From other people I have heard that it would, and from the mechanic he told me the opposite saying I would be wasting my money.
I'm looking at getting a turbo timer soon. I basically want to keep the GTR stock for about another year and then have enough money saved up to upgrade. What I don't want to have happen is the stock ceramic ones fall apart before then because I didn't have a BOV.
Cheers
Burgerman
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/
Doesnt the 32 GTR have the factory twin blow off setup like the 33 and 34?. My advice is dont bouncve off the limiter, treat your engine good and the stockers wont give you problems. there is a 33 in my country that still runs the stock turb setup, and that dude abuses his car, they still havent let go. but a BOV will help prevent compressor surge that translates in less stress on the exh wheel.
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2644006
Hi Guys,
Cheers
Burgerman
Your car has two factory BOV's, they are very good even for high hp applications, so you wont need to change them even when upgrading your turbo. Dont boost your turbo's over 1 bar and you should be safe aswell.
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2644036
The only reason aftermarket BOV's would benefit you is to prevent compressor surge. You can hear compressor surge if you have it. When you build boost, and let off, instead of the BOV compression release noise, its a bunch of short/fast compression releases, one after another... very obvious.
I actually think the stock BOV's would be better than aftermarket to prevent compressor surge. I noticed that my stock rb20 BOV was WAY more sensative than my blitz super sound, and now I actually hear a little compressor surge at like 1-2 psi boost.
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2644077
hi mate, i would personally not touch the original ones. guys over here in the uk have had problems when changing the std bov,s .the afms or maf as some call them do not like vent to atmo...causes over fuelling when changing gear. as for location. this is mine and the 32 are in the same spot under the front drivers headlight behind the bumper.. note i am running d-jetro hence blitz twin bov,s bernie/uk
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2644081
Another point worth thinking about is turbo timers.Basically I,and a lot of other people including some more knowledgeable,think they're a useless gimmick and a waste of money.Not only that but they can collect defect notices for you.There was a whole thread about them in the last week.You should be able to find it fairly easily.
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2644083
Thanks for the info guys, puts me a little more at ease. I'll check out info on turbo timers. At the moment before I park the car I don't boost it for 5 mins before I park it so as not to park it on overly hot turbos.
Looks like I need to get under my car more often and try and find those BOV's. It's just that the last car I had an RB20DET motor and it had a noisy BOV visible in the engine bay.
Thanks again for the help.
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2644166
I have noticed when I boost it and start to back off around 5 grand it will let off a series of sounds, anywhere from 3 to about 5 or 6 of them (hard to count cause it happens fast). Havn't really experimented by backing off quickly or slower to see if it makes a difference. Are there any other symptoms of compressor surge? it doesn't do it when I boost and change gear, only when I back off and stay in gear.
Also how bad is compressor surge to the life of the turbos? if I avoid boosting and backing off in the same gear will the turbos etc. be ok?
Cheers
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2675924
If you have the stock BOV's i would very much doubt you have comp surge.
the stock GTR BOV's do make some interesting noises when you they are getting rid of a bit of boost :)
You can also (if you practice) get them to almost alternate, that could be there your hearing "different" noises.
Its hard to explain :P
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2676049
the stock GTR BOV's do make some interesting noises when you they are getting rid of a bit of boost :kiss:
Its hard to explain :)
Hahahah "alternate" - thats it, your spot on. I had a dead stock bnr32 with a cat back and pods. When driving, u can still get it to flutter by backing off the right amount and holding the throttle still for a while.
When over 3500-4000k rpm u can get the two (alternating) tones, that then trail off, like a 'teeter totter' kinda sound? =)
I assume your sort of catching the BOV's out, with the right combinating in the intake track and plenum, they dont open and you get some reversion. As for the two tone thing, Iv never heard it on anything bar GTR's :)
M
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2679082
Yeah you do get quite alot of noise with stock blow off valves. Only you need a set of pod filters to hear it..
With stock recirculating blow off valves the air gets re-directed back into the intake of the turbos. Therefore when you back off completely you get that air hitting the compresor blades while they are slowing down. If you have a modified air filter setup (especially pods) you will hear this more due to the lack of extra baffling that the standard system has.
Correct me if im wrong..
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2679094
No, your dead right, but we arent talking when you completley back off, this is when you've got a decent amount of boost going, then back off quickly, just a little bit, must be around 10mm, and you hear it.
From memory you had to then match the further releasing of the peddle 'curve' with the sound to make it go for longer
Hope that makes sense
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2679112
I love the noise the twins make :P fluttering about between heavy throttle release .
They were quieter though when I had the stock turbos.....
Now the sounds have a higher pitch in the beggining when they open up and the flutter is more like
a large bird of prey....
LEAVE THEM ON.
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2679159
M
Yep, that "teeter totter" is the best term to describe it. Now I can tell people how it sounds instead of trying to compare it to something. I'll leave the factory BOV's on. Thanks for all your info and help guys.
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2679857
the stock GTR BOV's do make some interesting noises when you they are getting rid of a bit of boost :P
On a friends GTR we call this noise the angry panda, cous it sounds like a panda bear's mating call BAHAHAHA..
ne hoo, leave them on mate they are more than up to the task, although Ive been invloved in talk with people about them being more efficient if they were moved but theres not much room....so its a catch 22
Jez
https://www.sau.com.au/forums/topic/141983-bovs-on-r32-gtr/#findComment-2679941
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
