+++white Face Dials @ Bezels+++ Get In Now
I am trying to find out what globes are used in R32, R33, R34 for the benefit of all people who wish to buy LED globes.
Sean'O : if you are keen to pull apart your dash T5 is 5mm, T10 is 10mm DIAMETER.
:P I would probably rather wait till after my exams just in case i make a mistake or something because i need my car, thanks for the clarrification though, I'm pretty sure Kezza has a 32 doesn't he? surely he would know
Thanks trav
  • Replies 271
Posted Images
:P Thats 100% true shit mike! The LEDs from ebay are just the run of the mill $3 led they are very narrow viewing angle and are pointless for this type of application!
I know i have been their and done that! yeah the dash for the R32 are T10!!! im fair sure most if not all dials use the t10 its only when you get into AC control buttons ect they get smaller
if you want to waste ya money on ebay led junk, you may as well get some blue paint and just paint the blobes with it! lol
anyway time is ticking!!!!!!
kezza
as soon as the 8th 12 hits, NO more orders will be added!!!! 2 days to get all the info to japan!!! then a few days to get them all made, a week or two to get them from japan, then i will send them out!
kezza,
I'm fairly keen for white dials + brushed bezels with the chrome rings + Blue LED kit. So am i best to get white dials with BLUE numbers, or CLEAR numbers, so the LED's shine thru better?
yeah mate, the white face its self wont light up all spazz looking, just the numbers and the strokes as like a normal set of dials! to get a nice blue i would get the metalic blue dials and a nice blue LED kit! oh and the bezels!
I say this because the metalic dials have clear lines and numbers and that will let the leds shine heaps of light ;)
one way or another its going to look 100% better than stock :)
And thats ok simon! It was writen in first post of time order ect!
cheers
kezza
kezza,
do the R33 GTS-T white dials include a little dial for the stock boost gauge? I read thru the thread for your last group buy, and it sounds like they don't? but ive seen other dials available, that do come with the little dial background (see pic)
kezza,
ILL LOOK INTO IT NOW!!!!
I CANT REMEMBER OFF THE TOP OF MY HEAD!
SORRY DUDE, FOR SOME REASON THEY DONT MAKE THE PART IN THE BACK!
I DONT THINK YOU CAN GET INTO THAT PART OF THE DIAL ANYHOW. BECAUSE IT IS BEHIND THE DIALS THEM SELFS!
UNLESS YOU WANTED TO PULL ALL THE CLOCKS OUT AND ALSO REMOVE THE NEEDLES(f**k THAT)
YOU DONT WANT TO BE MUCKING AROUND WITH THAT SORT OF THENG. THE DIALS KITS FROM CYBER STORK, ARE MADE JUST TO BE A SIMPLE INSTALL!
WHEN YOU PULL NEEDLES OFF YOU WILL GET YOUR SELF IN TROUBLE!
HAHAHA ASK MY MATE KEITH, I GOT HIM A SET OF CARBON FIBER DIALS! AND THEY REQUIRED YOU O TAKE NEEDLES OFF!!! AND HE ENDED UP f**kING THE SPEEDO AND THE OIL DIAL!!!
NOT WORTH IT MATE!
SO THATS THE LOGIC I CAN SEE IN THEM NOT TRYING TO GET YOU TO FIT THAT BOOST DIAL DEHIND ALL THE OTHER CLOCKS!!!
What makes a good dial, compared with a "junk" one?
(Sorry if i'm askin too many Q's... will place my order shortly!)
the material they are printed on for one! And i have seen a set of those junk ones fall apart! heat in the car, poor grade translusent paints! BAD NEWS i dont mind the questions... im not making shit out of doing this so i dont mind if you dont get any dude! but like i said this is the last gb im doing so, tick tock tick tock
GB ends on the 8th and no more orders will be takin,
THANKS PEOPLE!
KEZZA :happy:
come on mate :) dont say that now...
I'm sure alot of people are very appreciative of your hard work in doing these GBs! :)
come on mate :( dont say that now...
I'm sure alot of people are very appreciative of your hard work in doing these GBs! :(
:P yeah yeah, lol! I hope so dude.... its not just a walk in the park! I spose i dont mind, car is getting painted in a few weeks so thats going to be WICKEEEEDDDDD!
Kezza put me down for set Blue MET dials package with appropriate bezels and blue LED lighting kit.
:laugh: not a problem mate!
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
