once you have all the main piping off and a few hoses.. about 5 mins to just undo all the retaining bolts..
anyway, ne i thought you took you plastic bit off to paint it? once you've done that to take the actual rocker covers off is rather easy... its just the sanding that is the hard part. Smoother result if you do the lot with hand sanding.. if you use some sort of mechanical sander + fine sandpaper its a lot quicker but you can get swirls in the metal which are hard to sand out via hand.
Me and nathan both did ours at the same time.. mine was really just to polish it up a bit more. Nathan's came up pretty well starting from standard. I'd post photos but i don't have a digi cam.
  • 3 weeks later...
Its probably not the greatest idea.. but i did it anyway :)
If the gasket crumbles when u take it off then yes, if not i would just put it back. Mine seems to be functioning fine after giving it some stick. It was a couple of weeks back now..
Does anyone want to put up a detailed report of how to achieve this result ?
I'm certainly willing to give it a go however no idea how to get the rocker covers or plenum off ...
If anyone is able to put a step by step up of taking off the inlet piping, rocker covers, plenum ... that'd be greatly appreciated :)
If anyone is able to put a step by step up of taking off the inlet piping, rocker covers, plenum ... that'd be greatly appreciated :P
Undo all the clips and bolts... Take the rocker cover off to get the the screws on the inside of the cam covers....
Dont loose any bolts etc while its apart! and take your time dont force anything...
I'd do it if I had a digi-cam but i don't so i can't help u all :D Wish i could, i'm good at tutorials and i've done it a few times.. Its useful to know to pull it apart change spark plugs, check coils and things too..
me and dj_lethal are gonna do our plenums fairly soon...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
