ok everyone, here is the official thread.. so lets get some numbers happening! If I've forgotten anything let me know, I just wanted to get a proper thread started... so people see it and have enough notice. Let's make it huge!!
DATE
Saturday 9 December
TIME
1.00 PM
LOCATION
National Museum Carpark
DETAILS
Cruise out to the Cotter for a BBQ lunch, then to a destination TBA for a photoshoot
PROVIDED
With our money in the kitty, I will be bringing: sausages, rissoles, bread, margarine, tomato sauce, plates, serviettes, cutlery and ice for the eskys. Depending on numbers I might be able to buy more stuff.
WHAT YOU NEED
You will need to bring your own drinks, and any other food you might want. Wash your car...and bring a camera!! Will add more if I think of it!
ATTENDING
Copy and paste the list from the person above you, adding your name to the list.
Shell & Damo
https://www.sau.com.au/forums/topic/143196-sau-act-christmas-cruise-2006/
  • Replies 146
Shell & Damo
Veilside R33 (Andrew)
tridentt150v
Chintami (Rachel) & Michael
Grant W
Bluprint
Baconer
Snooze
Frink
R3sp3ct
SL33KY (Emily)
leech_
skyline_babe5 (Cassi) & Amaru & Aurora
Slither(shawn)
was tempted to put my name at the top of the list lol
Shell & Damo
tridentt150v
Grant W
Bluprint
Baconer
Snooze
Frink
R3sp3ct
SL33KY (Emily)
leech_
Slither(shawn)
ANDREW!!! (skyGTRline)
Shell & Damo
tridentt150v
Grant W
Bluprint
Baconer
Snooze
Frink
R3sp3ct
SL33KY (Emily)
leech_
Slither(shawn)
MANG (simon)
Shell & Damo
tridentt150v
Grant W
Bluprint
Baconer
Snooze
Frink
R3sp3ct
SL33KY (Emily)
leech_
Slither(shawn)
MANG (simon)
YAF28F(Michael) 90% can go
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
