ok everyone, here is the official thread.. so lets get some numbers happening! If I've forgotten anything let me know, I just wanted to get a proper thread started... so people see it and have enough notice. Let's make it huge!!
DATE
Saturday 9 December
TIME
1.00 PM
LOCATION
National Museum Carpark
DETAILS
Cruise out to the Cotter for a BBQ lunch, then to a destination TBA for a photoshoot
PROVIDED
With our money in the kitty, I will be bringing: sausages, rissoles, bread, margarine, tomato sauce, plates, serviettes, cutlery and ice for the eskys. Depending on numbers I might be able to buy more stuff.
WHAT YOU NEED
You will need to bring your own drinks, and any other food you might want. Wash your car...and bring a camera!! Will add more if I think of it!
ATTENDING
Copy and paste the list from the person above you, adding your name to the list.
Shell & Damo
https://www.sau.com.au/forums/topic/143196-sau-act-christmas-cruise-2006/
  • Replies 146
Shell & Damo
Veilside R33 (Andrew)
tridentt150v
Chintami (Rachel) & Michael
Grant W
Bluprint
Baconer
Snooze
Frink
R3sp3ct
SL33KY (Emily)
leech_
skyline_babe5 (Cassi) & Amaru & Aurora
Slither(shawn)
was tempted to put my name at the top of the list lol
Shell & Damo
tridentt150v
Grant W
Bluprint
Baconer
Snooze
Frink
R3sp3ct
SL33KY (Emily)
leech_
Slither(shawn)
ANDREW!!! (skyGTRline)
Shell & Damo
tridentt150v
Grant W
Bluprint
Baconer
Snooze
Frink
R3sp3ct
SL33KY (Emily)
leech_
Slither(shawn)
MANG (simon)
Shell & Damo
tridentt150v
Grant W
Bluprint
Baconer
Snooze
Frink
R3sp3ct
SL33KY (Emily)
leech_
Slither(shawn)
MANG (simon)
YAF28F(Michael) 90% can go
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
