Hi Steveo,
Your mate doesnt have squat. I paid him money for one nearly 2 weeks ago under the pretense that he had stock in hand (well according to eBay he did) and I still havent got it. Please ensure nathan has stock in his hand before making comments like that.......
Tell him Sam is still patiently waiting for his PFC.
Also...when you speak to him tell him to get me that EMS tracking number ASAP
Hi Sam,
We don't know what Steve is on about regarding the fc's for the ECR33. He doesn't represent us and as I've told you, your computer should be arriving soon. As i've said we can give you a full refund if you are unhappy with waiting.
We'll be advertising on these forums soon and anybody is welcome to check out our warehouse at any time.
Kind regards,
Nathan.
  • Replies 126
Hi Steveo,
yo man i was just letting ppl know of someone who may have some in stock for those looking..
did i say he had some?
I was simply being helpful.......
Hi Sam,
Kind regards,
Nathan.
As Disccused
Thanx nathan. I understand things screw up sometimes and thats ok. Just keep me in the loop.
Also, when you have a spare minute can you get a price of a PFC boost control kit?
Also, you know that gauge holder we were speaking about before? Looking to get that aswell when it's all good and ready....
Hey Guys,
For all you ECR33 owners....a Melbourne based eBay mob called "online performace" has around 3 in stock right now. I have bought one off him earlier this week and spoke to him today and he seems like a real nice guy. I paid $1300 for mine and thats with the "12 MONTH AUSTRALIAN WARRANTY" bla bla bla which I think is a top price for a warrantly backed item
http://cgi.ebay.com.au/APEXI-Power-FC-with...1QQcmdZViewItem
Shutup Meiji, shes joking around with Kennedy..
Liz is the best any everyone knows that, if they don't know that then they havent met liz.
and sif no one talks to her in real life.. liz is like miss popular in nsw..
I ordered one from online performance autos, should receive it on Monday or Tuesday. So I guess he only has 2 left now for R33's. I know it costs a bit more through those guys, but I also wanted one badly, and they have always been part of the plans for my car, so I didn't really have an option.
Oh and the 12 month Australian warranty is good for peace of mind I guess.
ignore her - she's a troll (24.6 posts per day???? get a life!!!!!) and her insults always involve being gay. geez no wonder you spend so much time on the internet liz, no one would talk to you in real life.
mmmmm, how controversial. :action-smiley-069::D
I'll rephrase. Liz is short for Elizabeth. Elizabeth is another name for the Queen. The call her queen because she is super cool and you are ghey.
BTW...trolls need loving too.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
