Hey people, jut letting you's know that my life officially ended today. This morning at 3:40am i woke up to the sound of my car driving down my street, at first it didnt click a minute of thinking went by n i thought to myself, i've been living there for awhile now n dont know of any skylines that drive down my street. Thought i'd go check on it for peace of mind and sure enough there was a blank space where it was parked. It was parked on the front lawn facing the house. No broken glass was left behind, no evidence what so ever. I even had the battery disconnected for that reason but they found it and managed to bypass my immobiliser n start the car n drive off. Its so not cool, and i only had 3rd party fire n theft insurance so max payout from just cars 3rd party is 5k. along way off what i had in mind for the car but u cant help bad luck hey, be careful with our cars guys n gals
https://www.sau.com.au/forums/topic/143556-stolenrecovered-red-s1-r33-gts-t/
tough break. hope you find it. my mates series 5 rx-7 got stolen the same night he sold it. 1.5 weeks later cops found it dumped in richmond. hope yours was a joy ride like his was.
i always ask this question though, did you have a club lock?
Edited by (B1) MR_fanny
hi guys, its a series 1 r33 gtst, its had a custom respray red, 17inch bbs rims, has a dmd lip spoiler on bootlid, m spec front bar with the middle chopped out with a front mount as exterior noticeable parts. 838 HGO is number plate, on gold coast, car was stolen from coomera. cheers
I'll keep an eye out 4 u......I go to alot of houses due to work and travel all over the coast. Will let you know if i see anything.
ah sheet...sorry to hear the bad news mate...hopefully it'll turn up somewhere once it runs out of gas...
bit amazed that they went through the trouble of locating the immobiliser AND checked that the battery was disconnected...must have stalked u for some time and observed u doing it
Shit man, that sucks.. sorry to hear it. Hope those mofo's leave the car intact and in one piece, hope it gets recovered soon.
Thief's are the lowest mofo scum bags... hope they get punished, hope they receive a slow and painful death.
Edited by pretender-
stoopid mofo's prolly wanked off dreamin of a skyline but was too shit lazy to get a job and save up to buy one!!
must say that they sure know how to pick their ride tho...sweet lookin car mate...or rather ex-car (not rubbing salt on wound)
I would have a drive around your immediate neighbourhood and have a GOOD look at peoples yards,under houses etc.. sounds like they might have been watching you for a while...
see if your neighbours heard/saw something, have any suspicious cars been cruising around your area?
still it doesn't look good for you mate :)
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
