It now looks like I have a leak in my exhaust manifold gasket. GRRR.
So, does anyone think I can remove the manifold without taking the lines of the turbo?
My plan was to:
1. undo cat at front
2. take off intake piping
3. unbolt turbo from manifold
4. Take manifold and shielding off, holding turbo in place
5. replace gasket
What do you think?
https://www.sau.com.au/forums/topic/143635-taking-exhaust-manifold-off/
Depends, are your lines hoses/braided etc or std steel pipes. if steel pipes, no chance, if hoses then I'd reckon it could be done, I'd lower the turbo down and out of the way then it would be easy.
The good part about it is if you bend one and it snaps or fractures, you can replace them with braided lines and then you'll never have to worry about whether it can be done like that again...lol
For the 4 bolts involved + dumping your coolant, I reckon it would save time and swearing/knuckle grinding just taking the turbo off. Plus you will have more room to move the mainfold etc.
Edited by Lazy-Bastard
Just take the turbo off. Its 'only' 4 nuts and a couple of coolant lines. Adds another 30minutes on to the job IF you have the right tools. :D
At least then you can get in and clean up both surfaces correctly.
Its also difficult to torque up the exh manifold nuts correctly with the turbo on. Do use a torque wrench unless you want to be replacing another gasket + studs later down the track.
Their torque values are up surprisingly loose.
just take the pipes off and replace the oil and water at the same time..:(
When the turbo came off mine,in a similar situation to you,i found that the banjo bolt for the water line was calcified over closing off the flow of water of into the turbo significantly.So you might be able to avoid a future problem there.
More so on a stock turbo than an aftermarket 1 with new connecting parts.
I've found from experance that by trying to short cut doing something on an engine instead of doing it properly tends to make the job twice as long and often in the end you will have to do it anyway just waste time trying to short cut it ,but there are always exceptions to the rule good luck
cheers Peter
You learn as you get older "do it once do it properly "
I have found it easier when removing a manifold to just undo the manifold leaving the turbo bolted on unbolt the oil and water lines and lift the manifold and turbo out together with my hks manifold I usually unbolt the engine mount under the manifold jack the engine up a little as well ,makes it a little heaver when removing but this has always worked well for me
cheers Peter
if you think you blew the manifold gasket, i would remoove the turbo and replace the turbo to manifold gasket aswell just to be safe, as those nuts/bolts generaly rattle loose and then you have a blown manifold to turbo gasket 1 week after replacing your manifold to motor gasket.. just my 2cents
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
