Items:
hi flow/standard turbo to bolt strate up to r33 manifold
Extra Info:
must be good condition.one that has been reguarly used until basicly when i buy it.dont want any that have been sitting around for months and months.
Contact Details:
pm me.or txt me.4go my number so ill post it l8er on
Price and price conditions:
nothing over 500 for a hi flow etc cheaper for a stock turbo.[im a tite ass]haha
Edited by PRO AERO
Items:
Std r32 suspension
Extra Info:
looking to buy, or borrow, maybe swap with my bilsteins until i clear defect.
Contact Details:
pm, reply in my defected thread, or call me 0405 241 064
I can pick up from anywhere, but u can call me to wrok out the details.
Edited by Bl4cK32
Items:
stock 33 gear knob, or somthing thats not gona get 2 hot, and feels nice on the hand...
Extra Info:
mines got metal bits and it burns when the suns on it 4 a while :ninja:
Contact Details:
pm or mobile 0402 44 88 99 or msn [email protected]
wont sell my arm for one, pick up anywhere....haha
Items:
1 x BNR34 GTR rim
Extra Info:
will consider a pair but would prefer just the one
Contact Details:
PM me with any info
Around $300 without tyres and will consider a rim that would need a respray or even slight welds.
Items:
S13 Silvia SR20DE (Non Turbo) 5speed manual
Extra Info:
Has to be in good condition no rust, scratches, rips, burns dont want anything with really high km's. And DONT want a silvia with the brown interior :/
Contact Details:
PM me
Dont want to spend more than $7500 - $8000 just depends on the condition of the car aswell :ninja:
Items:
Blown (=cheap) R33 or R34 turbo (to hi-flow) - up to $150
R34GTT Rear spoiler - up to $200
R34GTT stock front bumper bar lower lip - up to $200
Contact Details:
PM/email me
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
