Items:
RB25det neo engine package
Extra Info:
prefer complete engine but let us know what u got or if u know of one 4 sale.
from r34 or stagea (non 4wd)
Contact Details:
0411 758 793
Price and price conditions:
Preferably cheap! depending on what u got
need standard 5 stud nissan rims for R33 4 door rb25det trying to get ready for murray bridge autofest in january 08
can sme 1 please help me out pm-me or just call me on
(Allan) 0401409575
cheers if any one can help.
Items:
R33 Series 1/1.5 Type-M front bar
Extra Info:
No deep scratches etc (except under the bar is ok).
Would be great if it were Wine Red in colour but any is fine.
Contact Details:
PM or 0401 926 276
Don't be a hero like autotech imports (they wanted $350 for a piece of junk)
Items Wanted:
R32 gtst type M side skirts and rear pods
Contact Details:
phone: 0409098923
email: [email protected]
Whatever is fair
Pretty sure drinkies ( http://www.skylinesaustralia.com/forums/m13898.html ) still has a set,
located in Nairne, adelaide hills
Items: standard skyline(any) catalytic converter (CAT)
Extra Info: Any condition
Contact Details: PM me here
Price and price conditions: Can come pick up where in Adelaide. Preferably cheap or swap for a single bottle of booze of your choice.
Edited by vietorious
WTB: Trust Power Extreme II Cat back zorst! new or used... prefer alot cheaper than RRP.
or I wouldnt mind a Buddy Club Spec III............ or or something custom 3-3.25" stainless steel cat back through a hi flow muffler and out a set of flutes....
Anyone out there have a 320kph instrument cluster for a BNR34
or know where to get a cheap one.
Peter 0400 850005
pretty sure JMS has one dunnow what the price is, would say pretty dear
im after 1 as well... Nismo with white face is sexy (Nengun has it for around $600)
apparently the led light background is red or orange?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
