Items:
Wanted R33 or R32 skyline
It can be:
A shell, unfinished project or with no motor and or gearbox
You car has engine problems and you wanna sell it
non Turbo r33 or 32
Or if you just wanna get 8 grand cash straight up for your skyline
Car has be fairly straight with good paint
Pay up too $8000
I have an Rb25 Engine and running gear just want to drop it into something
Contact Details:
call me on 0400285588 or sms but email me would be easier or add me on msn [email protected]
Items:
It can be:
non Turbo r33 or 32
Pay up too $8000
Contact Details:
seen a black r32 in last weeks trader for $7900, in good condition, even has a few goodies eg. cooler, aftermarket fuel pump... giv it a ring if your lucky it mite still be there...
Try the forum traders section, theres quite a few for sale in there
Thanks for that Damo, am aware of those.... Found some cheaper than that on Egay.... But would prefer to buy one of a SAU member to help them out.... Maybe even save some coin while im at it!
Im in the market for one myself, but new clutch, service and tune has cleaned me out for the time being. Personally i'd buy a new one, and you probably wont find cheaper than the specials in the trader section. Good luck!
WTB: Bride super low bottom mount rail suit R32 (4door if it makes a difference) preferably cheap as possible (unemployment doesn't pay much these days :banana:)
one fiddy @ jms for s13 one, drinkies can mod it to fit
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
