Items:
Wanted R33 or R32 skyline
It can be:
A shell, unfinished project or with no motor and or gearbox
You car has engine problems and you wanna sell it
non Turbo r33 or 32
Or if you just wanna get 8 grand cash straight up for your skyline
Car has be fairly straight with good paint
Pay up too $8000
I have an Rb25 Engine and running gear just want to drop it into something
Contact Details:
call me on 0400285588 or sms but email me would be easier or add me on msn [email protected]
Items:
It can be:
non Turbo r33 or 32
Pay up too $8000
Contact Details:
seen a black r32 in last weeks trader for $7900, in good condition, even has a few goodies eg. cooler, aftermarket fuel pump... giv it a ring if your lucky it mite still be there...
Try the forum traders section, theres quite a few for sale in there
Thanks for that Damo, am aware of those.... Found some cheaper than that on Egay.... But would prefer to buy one of a SAU member to help them out.... Maybe even save some coin while im at it!
Im in the market for one myself, but new clutch, service and tune has cleaned me out for the time being. Personally i'd buy a new one, and you probably wont find cheaper than the specials in the trader section. Good luck!
WTB: Bride super low bottom mount rail suit R32 (4door if it makes a difference) preferably cheap as possible (unemployment doesn't pay much these days :banana:)
one fiddy @ jms for s13 one, drinkies can mod it to fit
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
