Items:
I want used cooking oil.
Extra Info:
If anyone works in or knows of people with a fish and chip shop I am after their used oil.
Initially am after 30- 40L but will be after a constant supply if plans work out.
Contact Details:
Contact Greg on 0412075359 or PM.
Price and price conditions:
As close to free as possible.
What the heck are you planning to do with used cooking oil may i ask =P I once saw this tv show where they built this engine that ran on used cooking oil and they did exactly
the same thing (go around to fish and chip places asking for used cooking oil =P)
Run a diesel tractor off it. All ideas at the moment.
I wouldn't mind a 32GTR either.
If I could find an immaculate one, I would consider a swap with mine and some cash obviously.
i knew it all along.....jelous :D maybe all my insults have finally made you crack. ill swap ya 32gtr $10 your way and a coupon for a free upsize at mcdonalds
moving onto the topic at hand.
im after the black backing that go's between your speedo dials. dont need the whole thing as my dials are find n dandy, just had a dumb car theif break the black surrounding part a lil as pictured bottom left in this pic.
o and it must be gtr or possibly gts4 as i have a gts-t 1 in now and it blocks the 4wd light n has its speedo reseting hole in a different spot making it look ugly in my dash :( lesson learned never take car to that workshop again.
Edited by Inline 6
You went too far, I hate Maccas.....you had me at hello!!
Try one of these sunshine
Im after one of the following styles of wheel as a set of 4
R32 turbo stockies
R33 / S14 stockies
R34 stockies
or any other set of 15" or 16" alloy wheels with 5x114.3 pcd that are able to be used in a load rated application (ie car trailer). Will even consider ford alloys if anyone has a set (not accepting steelies/interceptors)
Not fussed on condition of tyres (they dont have to have them either). Going to have to buy some LT rated tyres for them anyway
Looking to have a set within the next 3-4 weeks max, as my trailer is due to be assembled in 5 weeks time
PM me, email me or drop me a message (with your name) to my mobile: 0409 049 299
Cheers
Matty T
Items:
factory r32 coupe side skirts in either black or silver (not gunmetal), factory r32 rear bumper in silver, may consider cheap after market bumper or skirts
Extra Info:
prefer in good condition no cracks faded paint etc
Contact Details:
pm me or txt me on 0447490437
Items:
Extra Info:
Contact Details:
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
