Cheap R32 gts-t 2 door, around the 7-8k mark =] for the mrs.
Im just about to put 1 through regency:
1990 nissan skyline r32 gts-t rb20det
5 speed manual
Black
18 inch wheels
turbo timer
Blow off
Has a scratch in the back left bumper.
Im after $7,000. Im just about to have the clutch and all front end bushes replaced for Regency appointment.
Hey guys. Im after some 17 or 18 inch rims for my 33 gtst. Want something with some good dish or some white drifteks. Let us know what u have. I have some 17 inch bbs rims on my car at the moment im willing to trade if someones keen. Theyre gold spokey ones with outer polished lip. Cheers, Mike
