want to borrow:
Girl, must be hot and good in bed. 18-26, attractive.
Pm me with offers
ah the old can i borrow you. only for an hour or so. but can you make sure the dishes are done by the time you leave. thanx :devil:
Im after a 3' Bellmouth Front/dump pipe for my s1 stagea (rb25)
ive got a bellmouth/dump/frontpipe off my r33 sitting at home made by boostworx
only problem is it was made for a highmount set up, but you prob get them to cut a section out and weld them both back together to make it shorter
the dump flange is for a standard rb25 turbo
$30
Edited by ovrtym33
$30
I think by the time I buy yours get them to mod it to a standard mount turbo it will be more than the $200 odd dollars it will cost me to buy a new one :(
$30
Got a pic of it? If its a high mount, won't the ex housing be rotated in the wrong position for a low mount turbo? Interested.
On that note ...
WTB split dump pipe or similar for RB25DET to replace stock dump pipe.
On that note ...
Can't edit, so here's a pic of what I'm after.
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
