Wanted White Work XD9 wheels and KU36 tyres either together or sold separately.
Fronts 18x9+20. Rears 18x10+18 in 5x114.3
KU36 - 2 x 225/40/18 & 2 x 245/35/18
Wheels are worth $2100 and tyres $850-900 brand new. Looking for someone not living on Fantasy Island who wants this sort of money or even more.....
jessie streeter can get u some rims for around $1800del.
Get on to this dude. He bought my old car with white XD9 in that size and has them for sale for $1800 with tires I think. Just msg him
http://www.facebook.com/?ref=home#!/pr...9553&ref=ts
thanks for the tip - i have f/b message him. do you have an email or phone number for him ?
also looking for some 400R clear indicators
genuine or TYC replacements
only really looking for the left side as i got the genuine and TYC right indicator
Factory 180SX Type X lights are the same part number. Japanese Import Spares stock these, about the cheapest place you will find for them too
WTB
R32 GTR Front Spoiler Lip - Plastic only - not the one that sits on the bonnet, the one that bolts onto the gtr front bar
R32 GTR N1 Sideskirts - Plastic only
R32 GTR N1 Rear Spoiler Lip - Fiberglass or plastic
R32 GTR N1 Rear Pods - Fiberglass or Plastic
only want in good or better condition. no missing chunks or busted screw holes
-D
I assumed they'd be different? different clusters etc?
Ive heard they read different, but I dont know for sure - My RB25 R32 has the RB20 one on it... Physically they are definately interchangable though.
Does it have a number on it?
maybe....
25070-30P01
Cheers
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
