WTB URGENT: r33 front lower control arms!!!
will pick up or pay for post or give sexual favours!
cheers
oi dude, read not long after your last request, someone had asked which side(s) you needed
have a chat to mitch
Urgently need a R33 gts-t manual gearbox asap or Steve is going to miss out on gazzanats and cry himself to sleep for the next few weeks.
If you have one please pm me with a price or call steve on 0419446847
Thanks.
looking for a cheap boonga... has to be rear wheel drive, manual, and running.... body condition doesnt matter, interior condition doesnt matter.... defected and unregistered doesnt matter.. it will never see a bitumen road again...looking to spend between $0 & $250.. will pickup from most areas of adelaide.....
PM me or TXT 0410982366
WTB: Front or rear R33 GTR Brembo brake pads or front rotors
i dont think ive still got the spare pads mike gave me with the calipers, but i do have some rotors i found just before that came over with the car. compared them to stock, and they look bigger than stocker 32r rotors. should compare them to my 33r rotors, and if they're any good u can hav them :D
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
