i can supply this , will have to order it in from my brain and it comes coupled with special cuddles , candles , hand woven rug & straw basket
enquire within
pm sent :P
Edited by SkyHi_33
Item
Nissan Skyline R34
Extra Info
Silver, just under 95xxxk's, needs new bushes, had minor scratch on side but hardly noticeable, books, tiptronic, 2.5L non turbo. May consider swap/trade, let me know what you have.
Contact
Phone 0433198277
Email [email protected]
No Pms as i cant reply
Price/Conditions
Im open to reasonable offers.
