looking for a s13 roof and or bootlip spoiler (r32 bootlip spoiler will be fine too)
not intirested in paying hundreds of dollars for new items cos its a track car and it dosent need to look super pretty
let me know if you have anything sitting around cheers
hey mate, i have a r32 gtr actuator.. if your interested
txt sent
Cheers.
i dont believe they are the same as what the dude's after
Anyone got an R33 bootlid? Preferably in white but I'll take what I can get. I have a plan in the works
ive got a white one =D
Edited by DamageInc
RB25 neo flywheel as i am pulling out the twin plate and going back to a single.
going by what ive heard shaun (someone correct me if im wrong) you should be able to use any RB flywheel for the job ;)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
