WTB
98 R34 Air Conditioner compressor and pully, must be working
i have one but dont think i need it for my 32 pretty sure lines will be different anyway does 32 compressor bolt up on neo braket??can anyone comfirm
WTB ASAP
hey ppl im desperatly trying to chase 3 Lifters for a RB20 im having a motor put together atm and 3 lifters have rusted on the top and have eaten the face of the lifter so i need to get some to replace
Can anybody help??
PLZ pm or call 0417 899 445 all help appreciated
Cheers Lockie
Wtb:-
r32 complete sunroof and roof lining
Clear / amber front indicators
RH projector headlight
2dr door weather stripes top and bottom
2dr 1/4 window upper moulds (inside)
Possably more things when I think of em!
Cheers damo
Anybody selling or throwing away:
R34 (Neo) or S2 Stagea (Neo) blown turbo ... I just need the housings, not fussed about anything else.
Or just the compressor housing if anyone has one lying around.
Please :D
Wtb:-
Cheers damo
Ive got a cefiro sunroof module. Yours free if you pick up.
r33 Seat belt holders
just like the one in the picture..
The holders come as a whole, with the seat belt too. it can be removed by making the hole in the holder slightly larger to slip the belt through it, but its a pain. i got mine from a wreckers, Import spares actually.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
